Go Back   TTORA Forum > Rock Crawling Tech > Solid Axle Swap Tech
Old 08-29-2007, 05:06 PM   #1
faithoffroad
faithoffroad's Avatar
Default steering cooler?
I've been having problems with my power steering lately either not enough fluid or its getting to hot. I am running the stock pump on a 2.7 and a Scout 2steering box. If I add a cooler on the low pressure side do yall think that would help both issues (capacity/heat)?
What sizes are yall running?
"If it has tit's or tires, you can be pretty sure your going to have problems with it"
faithoffroad is offline   Reply With Quote
Old 08-29-2007, 06:00 PM   #2
swank501
Thank God 4 Every Day
Yes Indeed. I think the heatsink style coolers are better for our sport since they require less airflow to cool. I was looking to upgrade mine, but I sold my Taco. The Volume increase wouldn't be huge, but it would be something more than you have now. You may look into upgrading to a larger reservoir if you want top increase flow significantly
gone to see the world...........
swank501 is offline   Reply With Quote
Old 08-29-2007, 07:21 PM   #3
trdtacostand04
i say dude alot
trdtacostand04's Avatar
Send a message via AIM to trdtacostand04
moroso model # MOR-42100
"the Black Widow" 2002 d-cab v6 4x4 33" trxus Mt's, ARB's F and R 8.4, manual hub conversion, king coilovers, camburg UCA's, deaver 8-leafs, downey shackles, 12" sb bilstein 7100 resi's, wheelers R brakeline, demello sliders, rear bumper/tirecarrier, front light bar, rear shock relocation, budbuilt ifs skid, can-back, urd gasket, airraid elbow, cross drilled/ slotted rotors, deckplate, full floating rear w/discs
trdtacostand04 is offline   Reply With Quote
Old 08-29-2007, 09:58 PM   #4
faithoffroad
Is this the heat sink style?
or is this?
Old 09-07-2007, 12:34 PM   #5
halfxspaid
halfxspaid's Avatar
Are you sure this is the right part number, i couldnt find it anywhere.
2003 x-cab 4x4 TRD
1985 toyota 4x4
halfxspaid is offline   Reply With Quote
Old 09-07-2007, 12:47 PM   #6
RedRunnertc
CO Chapter Prez
RedRunnertc's Avatar
When my radiator broke at Takeover, I put one from an auto tranny truck in there and am planning on using the tranny cooler section of the radiator for a power steering cooler.
Just need to figure out how to route the hoses.
President - CO Chapter
Founding President - OH Chapter
'93 4Runner lockers, armor, tcases, & stuff
'96 Impala SS - my own personal cop car
Check out pix at www.4wheelingoh.shutterfly.com/action
RedRunnertc is offline   Reply With Quote
Old 09-07-2007, 01:05 PM   #7
KStacoma
KStacoma's Avatar
Send a message via AIM to KStacoma
I have that exact one on mine, it made a huge difference. I was boiling fluid over before and out the cap but now it stays alot cooler although it still gets hot if i'm doing lots of tight technical stuff all day long.
SAS'd, 35's, locked fr/rr, 4.88's, Bobbed, Dovetailed, Caged. (SOLD)
KStacoma is offline   Reply With Quote
Old 09-07-2007, 03:55 PM   #8
TBob
Built II Beat Fabrication
TTORA BRONZE Sponsor
TBob's Avatar
yep same one I run - I mounted mine here and the part number is
Moroso 41200 from sumitt
Had God not driven man from the Garden of Eden, the Sierra Club would have.
Triple sticks
Potato Salad
Martinez
Upper Ajax
Pritchet Canyon
TBob is offline   Reply With Quote
Power Steering Cooler mojavehanna Early Tacoma Tech 5 03-22-2007 07:14 PM
possible free power steering cooler? drabnor Cheap Tricks 11 12-14-2006 12:57 PM
Auto tranny cooler- PS cooler? lVlr_87 Newbie Tech 7 11-19-2006 09:03 PM
Ram Assist steering cooler. Got some pics? 02tacotim Rock Buggy/Truggy Build Ups 10 10-31-2006 12:48 PM
A Power Steering Cooler is Your Friend Timbuddha Solid Axle Swap Tech 42 04-18-2005 09:34 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
