I see that ORS is offering "Holiday" rates for their Manual Hub Kit. I've been eyeing this kit for some time... and the extra $100 off might push me over the edge. I also see that they now offer a "NEW" kit. One that does not ship with the Warn Hubs. Is says you can use either Aisin or Mile-marker hubs. I think I might like to get the cheaper kit ($789) and order my own Aisin hubs. Before I do......
Could someone school me about the differences between Aisin/Warn. Is Aisin really stronger?? Does one stick out farther than the other?? Are there different "levels" of Aisin hubs? Meaning, are there different models to choose from. One being the cheap$$ route, while maybe another is the HIGH END model??? How much are NEW Aisin hubs?? Can I just go to Toyota and order them? Again, what model would I order?? Any other info would be great. I'm just trying to educate myself on this a little bit more. Also, how do you pronounce AISIN?? |
#2 |
Gotta bump this for the detailed info on why the Aisin's are better. I'd love to know as well
I've been told time and time again that Aisin are far better than pretty much any other hub on the market. I can also say that Ive never seen a completly busted Aisin on the trail... A few that had some issues but, never anything that didnt get them out. Many O Warn's I've seen destroyed though. Price--- Chances are, your gonna pay sum bux for them new. Hopefully someone will chime in with more detailed knowledge!?! |
As far as why Aisins are regarded as the best, I don't know. However, I did convert to manul hubs with junkyard parts off of a 2000 for $400. I do know that the Warn hubs stick out further than the Aisins.
Matt |
#4 |
Aisin hubs simply have a proven track record. I can't tell you exactly why they are stronger but they are. One thing that makes them stronger is that they use the cone washers. I know that the warm/milemarker hubs for the toyota solid axle do not use the cone washers. I am not sure about the warn/milemarker IFS stuff.
I would definately not use warn hubs. Buying new hubs from the dealer is going to hurt. See if you can't find a set in a local bone yard or check out http://www.car-part.com/. later! shane
i found the cure for hope |
#5 |
Random Dude
The aisin hubs don't stick out nearly as far as warns. So, in theory they're less likely to get bashed.
#6 |
Random Dude
I should note, I have warns for my SASed rig and they've come out with some -huge- gashes in them from rocks, but, still turn like new.
#7 |
I know that my Aisin hubs have never let me down
#8 |
concussed
![]() Join Date: Dec 2004
i have warn premiums on my ifs rig and they dont stick out any further than stock.what i dont like about warns are the fact that you have to turn them full around.as compared to half turn stock.waa.
KRYPT0 black and blue. ttora member since '99 '95.5 wheeler built,crashed,rebuilding '05 klr650 my one wheel drive taco! I have to say, Thanks for all the responses, good and bad, it just wouldnt be ttora without a few "kill yourself" replies. |
#9 | |
I'm still running the stock Aisin's on my truck, but I may switch to Warn premium IF the Aisin't ever give me trouble.
No Tacoma anymore, had to go bigger and couldn't afford a Tundra. 2005 Ram 1500 Hemi 4x4 Quad Cab |
#10 |
Thanks for the info... What about price??? Can I get a set of (new)Aisin hubs for $200-$250?? With the reduced price ORS is offering, I can get the
Aisin hubs for about the same price they offer their "full" kit with the Warn hubs. I think that would make me buy!! |
#11 | |
#12 | |
Each?? As in $400 total. I'll make a few phone calls. Thanks for the estimate. |
#13 | |
Hub Body: 43508-35040 $ 66.63 Hub Cover: 43509-35040 $ 76.49 Cone Washer: 42323-60010 (Quantity 6) $ 2.33 Hub Body Nut: 90170-08036 (Quantity 6) $ 0.64 Hub Body Washer: 90201-08042 (Quantity 6) $ 1.59 Cover Bolt with Washer: 91641-80616 (Quantity 6) $ 0.50 gaskets 43531-60010 $ 1.11 43422-60060 $ 1.38 Total $ 175.97 for each side, soooooooooo that's $351.94 Total unless I screwed up my math. The washer with splines inside it is about $10.00 each, I think it would come with the ORS kit though. It's in the pic on their site. I bought used ones at a junkyard for $75.00 each, everything was included except the inner gaskets. |
#14 | |
GRUMPY SOB!!
You wont ever have a Problem as long as you clean and grease them every once in a while. |
#15 |
Cracker
![]() Join Date: Nov 2004
TTORA cost is only $336.38
#16 | |
#17 | |
#18 | |
#19 | |
#20 | |
#21 | |
dee-de-dee
Call chris and get the aisin's, i hate freaking warn hubs...
just a POS buggy
#22 |
Thanks for all the info! Although, I'm still wondering if I should do it. What if something happens to the shaft (i.e. I brake it, or someone t-bones me). I got to get a custom shaft make again. It's not like I can pick up a new one at me nearest shop (being longer and-all). I'm not sure I like the idea of being "dependent" on ORS for any new shafts in the furture. I'm just thinking out loud.
#23 | |
BTW, if Norm answers, ask for Mike [owner] He may be busy and may have to call you back. Also, if you decide to buy, ask Mike if he can hook you up even more with a TTORA discount... Worth a try
#24 | |
#25 | |
