Go Back   TTORA Forum > General Tech > Suspension
Old 02-07-2006, 06:17 PM   #1
TacoMike82
TacoMike82's Avatar
Default TC UCAs vs Camburg UCAs
Just wondering why the Total Chaos UCAs are $600 and the Camburgs are $439? What are the differences between the two that put the premium on the TCs?
2007 FJ Cruiser, 6 Speed, RoughCountry 3" Spacer, 17x9 DC-1, 33x12.5 MT Baja Claws, TRD CAI, Flowmaster 40 Series, URD ShortShifter
2009 Access Cab Taco, 4x4, 6 Speed, TRD Off Road, 3" ToyTec Spacer, Toy Tec AAL, 17x9 ATX Artillery, 285/70/17 Goodyear Duratracs, TRD CAI, Flowmaster 40 Series
TacoMike82 is offline   Reply With Quote
Old 02-07-2006, 07:24 PM   #2
themariachi
asdf
themariachi's Avatar
I think it has to do with the uniball that is used.
themariachi is offline   Reply With Quote
Old 02-07-2006, 07:28 PM   #3
themariachi
asdf
Ah, here it is.
http://www.off-road.com/toyota/proje..._over_compare/
Old 02-07-2006, 08:18 PM   #4
genrec
Get the camburg.....better bang for the buck...you will not be able to tell any difference between the 2........
genrec is offline   Reply With Quote
Old 02-07-2006, 08:34 PM   #5
4BYnTacoma
4BYnTacoma's Avatar
Send a message via AIM to 4BYnTacoma
It seems to me that I hear about uni-ball noise more from the camburg users. Something abou them not taking an extra step when installing the cup that holds the uni-ball that TC does.
I am personally waiting for the Donahoes to decide if I am gonna go with a new UCA.
2004 V6 5spd 4x4: 2.5 CF Spacers, Bilstein HD's, Deaver 3 Leaf AAL, Rancho 9000's, 15x8 Black Rock Crawlers, 32x1150 BFG Muds
4BYnTacoma is offline   Reply With Quote
Old 02-07-2006, 08:48 PM   #6
joel
Mud’s the devil
joel's Avatar
Total chaos uses a solid slug in place of the uniball cup when putting there control arms together. They weld it to the control arm and then machine it out to exact specs. That way the uniball fits in the cup perfectly every time. Camburg uses the cup that comes with the ball. During the welding process, the heat warps the cup, making the tolerances less consistent. This leads to premature uniball failure and noise.
FOR SALE
Built 95.5, std. cab, Manual, 3.4 v6 Tacoma
http://www.tacomaterritory.com/forum...19#post1802619
joel is offline   Reply With Quote
Old 02-07-2006, 09:00 PM   #7
Tweeter
Desert Moderator
Tweeter's Avatar
Send a message via AIM to Tweeter
Yea I don't hear too many other guys with the TC arms complaining. They can be tight the first month or so but are butter from there on out. I got Camburgs right now but will be using a totally different kit in a little bit here, so I'll see if I notice any difference...
www.chaosfab.com
www.foxracing.com
www.deaverspring.com
www.mullenfabworks.com
My truck is for sale!!!
- "When a cop flashes his lights at you he's not really asking you to pull over. He's challenging you to a race." - The Book of the Piece
Tweeter is offline   Reply With Quote
Old 02-07-2006, 11:16 PM   #8
themariachi
asdf
If you are going with the ex. travel hoes, you are going to have to get UCAs.
Old 02-07-2006, 11:21 PM   #9
DesertTRD
DesertTRD's Avatar
Send a message via AIM to DesertTRD
they dont machine them out, they use the slug as a filler for where the uniball would be, ie the cup is still the same cup as camburg, however this doesnt cause noise from distortion not using hte slug would mean if your cups were tight to begin with then the uniball probably wont fit afterwards, which camburgs fit fine....
Sometimes you have to wonder if people were born that stupid...
DesertTRD is offline   Reply With Quote
Old 02-08-2006, 12:30 AM   #10
YoTRacer158
YoTRacer158's Avatar
Send a message via AIM to YoTRacer158 Send a message via Yahoo to YoTRacer158
Definately go with the UCA's and extended Donahoes...it's well worth the money for the extra travel and the lower roll center
2004 V6 5spd 4x4: TRD Charger, URD Fuel Mods/AFR/Unlimiter/2.1" Pulley/Crank Pulley/Short Throw, Supra MAF, TrueFlow Filter, JBA Ti Ceramic Headers, SpinTech Exhaust, SPEC Stage 3+ Clutch, BentUp Front Bumper, Chaos LT/Kings, 62" Deavers/18" Kings/, Glassworks Supercharger Hood/Fenders/Bedsides, 15x8 Black Steelies, 33x12.5 Claws, 4.56's, RR Solid Motor Mounts
youtube.com/YoTRacer158
YoTRacer158 is offline   Reply With Quote
Old 02-08-2006, 09:22 AM   #11
genrec
I've run the Cambrurgs on my tundra without a sound....i say its whoever installs them..if they are done correctly......i have seen just as many complaint on both UCA's......i will stick to camburg on my new taco........and spend the left over money else where.
Old 02-08-2006, 03:47 PM   #12
Super Doody
Hot Showers and Blow Jobs
Super Doody's Avatar
Another little difference I noticed is that camburg uses regular zerk fitings while total chaos 90 degree zerk fittings. Its easier to lube your bushing with the 90 degree zerk fitting. I'm thinking about swaping to the 90 degree ones.
Jim
2003 4x4 V6 TRD
SC with URD kit, Aquamist 2D, 2.2 Gen 2 Super Grip Pulley, Donahoe Coilovers, Camburg UCAs, Deaver Leaf Pack, Goodyear MTR 265/75/16, Alpine 9830, Sirius Sat. Alp1., Corbeau Legacy Seats,
Super Doody is offline   Reply With Quote
Old 02-08-2006, 03:58 PM   #13
themariachi
asdf
That's not a bad idea.
Old 02-08-2006, 04:35 PM   #14
4BYnTacoma
4BYnTacoma's Avatar
I was talking about waiting for the Donahoe upper control arms to decide if I am gonna go with some after market control arms... i will go nuts if i have to hear my truck squeaking all the time.
Old 02-08-2006, 04:39 PM   #15
TORR
TORR's Avatar
Have we all forgotten that Camburg dont give you new circlips with the arms? And you eat circlips because the slug adapter is machined wrong? I dont like to start stuff, but it seems that the extra $161 you spend on the TC arms gets you a little more time spent thinking out the product. By the time you buy new 90deg. zerks, a couple of circlips, and a new set of uniballs, you are above the price of the TC arms. Food for thought.
True Off-Road Systems
danf@trueoffroad.com
(805)784-9418
TORR is offline   Reply With Quote
Old 02-08-2006, 04:48 PM   #16
Tweeter
Desert Moderator
Tweeter's Avatar
After awhile a part of you just gives up...you will eventually not care like the rest of us...
www.chaosfab.com
www.foxracing.com
Old 02-08-2006, 05:00 PM   #17
Super Doody
I really dont think you can compare the two control based on what people say here because there are way more people here with camburg arms than people with tc ucas. You'll have have to do a direct comparision.
Jim
2003 4x4 V6 TRD
Old 02-08-2006, 08:33 PM   #18
joel
Mud’s the devil
joel's Avatar
The distortion of the cup would cause excessive noise and where wouldn't they? If the ball is designed for a round cup and the cup is oval, it will "rub" harder in one spot than another. Therefore adding excessive wear and noise from hard metal to metal contact. Along with lack of contact and close tolerance in other places. Please correct me if I'm wrong, it just seams obvious, right?
FOR SALE
Old 02-08-2006, 09:31 PM   #19
themariachi
asdf
You weren't clear. I get cha'.
Old 02-08-2006, 11:27 PM   #20
dcpunk123
Taco No More
dcpunk123's Avatar
uniball
the uniball is a one piece unit thats pressed into a cup
uniball cup
a uniball may not fit properly in a distorted cup
dcpunk123 is offline   Reply With Quote
Old 02-18-2007, 08:27 AM   #21
DavidTaylor9
DavidTaylor9's Avatar
The Total chaos arms are more beacause insurance purposes
2003 Toyota Sequoia SR5 4x4 V8
R.I.P 2003 Toyota Tacoma TRD all D'Hoed up
"I wish exacto was emo, so he would cut himself."
ƃɐqǝɥɔnop ɐ sı ʎʇıɹnd
Originally Posted by GMAK View Post
if theres grass on the field, play ball.
Originally Posted by luni View Post
If there isn't flip her over and play in the mud
DavidTaylor9 is offline   Reply With Quote
Old 02-18-2007, 10:15 AM   #22
Supramann93
Supramann93's Avatar
I have the Total Chaos uppers C.A.'s, because Camburg was behind on manufacturing theirs and it might have taken a few days to a few weeks to get. I am extremely happy with the Total chaos UCAs and there was a bit of noise after "breaking them in" through mud and water but the noise subsided after a few days. We greased the hell out of them when installing.
2004 Tacoma X-Cab No Mo-Supercharger
URD Fuel kit, URD short throw, Magnaflow exhaust. Donahoes, Total Chaos UCA's, Deaver 8-pack. Demello Sliders, Piaa headlights (harness also) A pillar Gauges, Tint all around, Rear breather extension, BFG 32" all terrains on 16" aluminum rims from Wheelers. Line-X, more to come...(thats what she said)
Supramann93 is offline   Reply With Quote
Old 02-18-2007, 02:26 PM   #23
Happysmiley
Happysmiley's Avatar
TC uses 4130 Cromo, Camburg uses DOM
Happysmiley is offline   Reply With Quote
Old 02-18-2007, 07:43 PM   #24
joel
Mud’s the devil
joel's Avatar
wow, old thread
FOR SALE
Old 09-12-2007, 02:11 PM   #25
vegaskurt
vegaskurt's Avatar
Digging this one back up since its now a $110 difference if you order them at wheelers. I'm getting ready to make my purchase and cant decide. Can anyone think of any other advantages for going with TC?
90 degree zerk on TC
4130 on TC
Higher quality Unibal on TC
1997 Limited 4runner | Stubbs Sliders | Budbuilt Skid+belly | Homemade Front / Rear Bumpers
vegaskurt is offline   Reply With Quote
Old 09-12-2007, 11:59 PM   #26
jentzschman
jentzschman's Avatar
Originally Posted by themariachi View Post
KILLER article!!!!
Thank you!
jentzschman is offline   Reply With Quote
Old 09-18-2007, 11:20 PM   #27
themariachi
asdf
Originally Posted by jentzschman View Post
KILLER article!!!!
Thank you!
Old 09-19-2007, 01:56 AM   #28
jzaiden
TTORA GOLD Sponsor
jzaiden's Avatar
Camburg does not use a Cheaper uni-ball. We use a Made in the USA Aurora. This is the same uniball used by many Trophy Truck and Class one race teams. We also use these on our race truck and never have any failures. We do may things that make our arms the best. One piece adapter for more wheel travel and less bind. All stainless steel spacers, Energy suspension urethane bushings, Zirk fittings, Bomalloy hardware way stronger than f-911. As for the squeak it is a uniball they make noise. I have these on my 2007 Tundra and with a little lube they don't make noise. You need to give to gain.
Note... the adapter (lower spacer) we use in the spindle. This i s a heat treated stainless steel part. This cost over three times more than the other guys. As for 4130 well our uniball cup is 4130 but we have our reasons for the tube to be DOM.. Same price as 4130. Don't get all cought up in the buzz words... Our arms are priced fair for what it takes to make them. We are not trying to gouge you guys. We are just charging you for our time it takes to make these and the materials. Now we do our own CNC work in house so maybe this is one of the reasons why you get a better price on a Camburg part.
Camburg Engineering, your #1 solution for performance suspension on your off-road truck!
Main Camburg Webpage
http://www.camburg.com
2005 Toyota Tacoma Page
http://www.camburg.com/tacomaP05.html
1995-2004 Toyota Tacoma page
http://www.camburg.com/tacomaP.html
jzaiden is offline   Reply With Quote
Old 09-19-2007, 11:47 PM   #29
sk8erkidGK
sk8erkidGK's Avatar
not a camburg man, but you can't beat the price, spend the extra money on another truck investment!
2002 Tacoma v6 4x4
Total Chaos LT w/ 2.5 Kings
33 Goodyear Wrangler Silent Armor
Deaver Replacement Pack w/ Bilstein 5150's
TRD headers & exhaust
TRD Supercharger
URD 7th, 2.2 pulley
sk8erkidGK is online now   Reply With Quote
Old 09-20-2007, 03:31 PM   #30
S/CTaco
S/CTaco's Avatar
Do either of the UCA companies have warranties for their products? Like insure proper fit, angles, allignment, ect.?
2002 TRD 4x4 - 2.0 SAWs, Camburg UCA, Deaver 9pack, 5125s, N/A 3.4, TRD headers, TRD Exhaust, Grey Wire Mod, 2 Low Mod, Tranny cooler, 265/75/16 BFG ATs, Downey Skid, 4x Sliders, demello rear bumper Bed Bar and more to come.
1988 Honda CRX (project) - B18b swap, Intake, Intake Manifold, Headers, Exhaust, 8lb flywheel, buddyclub coilovers and more to come. (FOR SALE)
S/CTaco is offline   Reply With Quote
rubber bushings in camburg UCA's? Marty McFly Suspension 14 02-05-2006 12:45 AM
Camburg UCA's & Fabtech 6" Lift Critt50 Suspension 1 01-30-2006 08:49 PM
FS: NEW Donahoe extended coilovers and Camburg UCAs 02taco4x4 Parts/Electronics/Wheels & Tires For Sale 19 09-17-2005 01:07 PM
ext hoes, camburg ucas, deavers(8pk), 5100s hexass2000 Wanted 0 09-15-2005 03:43 AM
SS brake lines with Camburg UCAs cloomis3 Newbie Tech 4 08-16-2005 09:13 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
