Go Back   TTORA Forum > General Tech > Fabrication/Tools
Old 01-16-2006, 08:19 AM   #1
tenntaco
Send a message via AIM to tenntaco
Default Welding on Axle Tubes
Is there anything special I need to know about welding on an axle housing? I know you can warp them, but I figured there may be some specific things I need to watch out for. Advice?
Thanks in advance.
tenntaco is offline   Reply With Quote
Old 01-16-2006, 08:36 AM   #2
Bear
H-O-L-Y-------S-H-I-T-H-H-A-A
Bear's Avatar
You got most of it figured out by knowing it is possible to warp them, but the only other thing I can think of is to make sure you clean/grind the area really well. Nothing like grease and road grime to contaminate a good weld!
I would say just follow your "basics" and you should be good to go, are you welding toward the diff or toward the outer part of the axle? The reason for question is, because some of the areas, can get pretty tight to get a nozzle into.
BEAR
Originally Posted by abbott
… remember, in the world of cars and trucks, its not cubic inches, its cubic dollars.
Bear is offline   Reply With Quote
Old 01-16-2006, 08:42 AM   #3
ATLRoach
www.shutupandwheel.com
ATLRoach's Avatar
Send a message via AIM to ATLRoach
Daniel... Work a little area at a time. Allow to cool and move to the other side.
Kyle
Never Ending V8 Powered Truggy build up
03 Tundra - Stock
06 Gixxer 750 - Not stock
ATLRoach is offline   Reply With Quote
Old 01-16-2006, 09:33 AM   #4
tenntaco
I'm helping my brother with a SPOA on his samurai, so it's near the knuckles.
Old 01-16-2006, 09:34 AM   #5
tenntaco
That's basically what I've been doing. I need to go back over there tomorrow night to finish the front and get the axles back underneath. Yesterday I ran out of wire.
Old 01-16-2006, 11:38 AM   #6
Ted
wut?
Ted's Avatar
Send a message via AIM to Ted
Are you welding on new perches? You would have to work hard to mess up the axle welding on perches. Just make sure you get them at the right angle. If you weld on a truss, you really have to be careful, you can really cause some warpage.
Ted is offline   Reply With Quote
Old 01-16-2006, 12:17 PM   #7
tenntaco
Yeah, perches. The kit he got uses a design that pretty much aligns itself using the stock bottom perches. I did notice that the first rear perch I welded on was slightly out of line. Basically if you were looking down at it, it is rotated very slightly in a counterclockwise direction. The top of the plate is parrallel with the others, so I figured that wouldn't be a big issue, as long as it's not bad enough to keep the new ubolts from bolting on. I guess I can straighten it up if I need to, though.
Old 01-16-2006, 05:06 PM   #8
tanKoma
The Satanic Panic
tanKoma's Avatar
Send a message via AIM to tanKoma
also be careful u dont weld any bearings in the diff, put the work clamp where the current wont travel thru there
i have too many damn car projects
99 x cab SOLD
02 trans am ws6
1953 bel air rat rod
1950 chevy 3800
tanKoma is offline   Reply With Quote
Old 01-16-2006, 06:37 PM   #9
tenntaco
Can you elaborate on that?
Old 01-16-2006, 06:50 PM   #10
tacd44
Tacoma-dana 44
tacd44's Avatar
He is conserned that if electrical current from welding travels through any bearings they might melt form the heat.
I don't know if that's an issue or not, I won't argue it. But, keeping the clamp close to the work can help protect the CPU. I think someone on the board damaged their CPU welding.
Cal4Wheel Member #4617
My Website
WikiPedia List of Toyota Engines
tacd44 is offline   Reply With Quote
Old 01-16-2006, 11:21 PM   #11
tanKoma
The Satanic Panic
tanKoma's Avatar
i other words, the arc can travel thru ur bearings if its grounded in the wrong spot, like welding on the axle housing and puttin the clamp on the driveshaft
99 x cab SOLD
02 trans am ws6
1950 chevy 3800
Old 01-17-2006, 08:08 AM   #12
Boheefus
BMFWIC
Boheefus's Avatar
be sure to pull the seals sout or they will melt, like the other said, a little at a time will get the job done no problem
(Flexion), 99tacx, BadBradHaz, DentedTacoma, hawaiianbro, jwbehm, rdtf, vanguard all love the cawk...I have proof.
myspace
Boheefus is offline   Reply With Quote
Old 01-17-2006, 11:56 AM   #13
tenntaco
Well, no worries about that. The sami is on stands and the axles are laying on the other side of the garage. I would have never thought to take the axle seals out, but if they got messed up it's no biggy. I'm sure they're only a few bucks to replace.
Old 01-20-2006, 12:23 AM   #14
tacokid1187
Send a message via AIM to tacokid1187
Unhook the batetry before begining your welds. Like someone said, the current can mess with electrical stuff mainly CPUs if not unhooked
1998 Tacoma X-tra Cab SR-5 TRD 3.4 V-6/5 spd S/C
285/75-16 Dueler M/T on TRD Ivans 2" RB BL w/ Gap Guards, Deaver 3-leaf, Bilstein 7100 SB's, Custom Bilstein 6100 Coilovers w/ Eibach Coils, AP UCA's, Poly Rack Bushings, Deck Plate, TRD Filter, LCE Rotors Hawk Pads, Optima Red Top, 04 Flares/Tail lights, Leer Shell, Pioneer CD Player, T4R Seats, Tweeter Housings and leather Steering Wheel, Custom Tube Bumper, Hella 500's, PIAA 004XT,
tacokid1187 is offline   Reply With Quote
How far forward do I need to place this axle? Winch Solid Axle Swap Tech 14 01-09-2006 12:19 PM
Found an axle, but..... 4307 Off Topic 14 11-06-2005 04:06 AM
Moving rear axle forward synovus Early Tacoma Tech 24 08-25-2005 11:55 PM
Rear (outer) axle seal help pportera Early Tacoma Tech 5 05-31-2005 12:01 PM
Rear end clunk (not axle wrap?) BajaTaco Early Tacoma Tech 28 04-07-2005 06:30 PM
