#31 |
Some pics of it on the van.
D
2000 taco 4x4 ext. cab v6 manual. ap sliders, u bolt flip, ome 882/dakar/c. shocks/greaseable shackles, ss brk lines, bud built skid and belly pan, ext diff brthr, dp, 33x10.5x15 bfg mt's on stock alloys, 04 trd e lok rear axle, demello hybrid r bumper and bed bar, custom front bumper/rear diff skid,heated drivers seat. 93 FZJ80 Aussie locked, body worked, and welded on. Last edited by darwink1; 08-20-2009 at 07:05 PM. |
#32 |
i quickly skimmed through and couldn't find how much you payed for this cruiser. how much was it?
Drive a hybrid, I need your gas. '04 Tacoma Ext. Cab SR5 TRD 4x4 allpro bilstein/eibach coilovers, uca's, 3" rear springs + 1 1/4" lift shackles, arb bumper, trd muffler, 1200lb marlin crawler clutch more to come... |
#33 |
Too much, but 1/3 less than dude wanted.........
Painted the card board to look like steel. Its sweet! Finish welding the winch box as we speak. D
#34 |
More bumper.
Its turning out ok, end is in sight. 4 more little pieces to cut and weld then more grinding..... D
2000 taco 4x4 ext. cab v6 manual. ap sliders, u bolt flip, ome 882/dakar/c. shocks/greaseable shackles, ss brk lines, bud built skid and belly pan, ext diff brthr, dp, 33x10.5x15 bfg mt's on stock alloys, 04 trd e lok rear axle, demello hybrid r bumper and bed bar, custom front bumper/rear diff skid,heated drivers seat. 93 FZJ80 Aussie locked, body worked, and welded on. Last edited by darwink1; 08-20-2009 at 07:06 PM. |
#35 |
Well finished er up today and I must say I really like the way it looks. Glad I took the time to buff it out before primer and paint. Just need Sam to bend me up a lil piece of tube in his spare time to connect the 2 sides of the winch box and act as a little stinger/light mount.
Oh yeah, did the poser flex thing and tried out the low gear. Lifted the rear no spinnage. I really really like this thing man. D
#36 |
Painted the wheelchair load out on the back if the bus today. Pete stopped in and I put the bastard to work scuffing up the rims. Primer, paint, and clear. They look like new rims. Also cut the huge assed tail pipe down a little, it sounds deeper now at idle.
Got a new rear diff breather fitting and ran it to the engine bay beside the one for the front axle. I think thats it for today. Thanks testico, and thanks for the case chris. D
#37 |
Well played hockey today and ended up messin w the LC afterward.
Masked and painted the front grille, fixed the rear hatch handle, fixed the glove box, and put on the stock rear bumper plastic till I figure out whats gonna happen back there. D
2000 taco 4x4 ext. cab v6 manual. ap sliders, u bolt flip, ome 882/dakar/c. shocks/greaseable shackles, ss brk lines, bud built skid and belly pan, ext diff brthr, dp, 33x10.5x15 bfg mt's on stock alloys, 04 trd e lok rear axle, demello hybrid r bumper and bed bar, custom front bumper/rear diff skid,heated drivers seat. 93 FZJ80 Aussie locked, body worked, and welded on. Last edited by darwink1; 08-20-2009 at 07:07 PM. |
#38 |
Made the front skid today. Its pretty, 1/4" hardened steel pretty lol. Lifted the front of the 3 ton 80 w it and it did not bend. Thats without the angled piece welded in....
Should do for gettin in and out of the driveway this winter. Cut the frame flush. Voila D
#39 |
I took Dan's advice and cut out a portion of my skid so air could get to the ps cooler. Makes it look better too.
D
#40 |
Well Pete came over and motivated me do dig into the body work again.
We ripped off the bumper, lights, signals, grille and markers so we could get at the sheet metal under the grille. This area was prepped while I welded the flare holes shut. We dealt w all the wheel well rust as well. Primer, rocker guard, paint (under the grille and lights) and another half assed job is off the list. Cowl work from friday D
2000 taco 4x4 ext. cab v6 manual. ap sliders, u bolt flip, ome 882/dakar/c. shocks/greaseable shackles, ss brk lines, bud built skid and belly pan, ext diff brthr, dp, 33x10.5x15 bfg mt's on stock alloys, 04 trd e lok rear axle, demello hybrid r bumper and bed bar, custom front bumper/rear diff skid,heated drivers seat. 93 FZJ80 Aussie locked, body worked, and welded on. Last edited by darwink1; 08-20-2009 at 07:08 PM. |
#41 |
Well, got up too late to go wheeling with any of the 10 groups goin out today so I hacked at the cruiser some more. Yes pete stopped by for a bit. Yes by hacked I mean hacked and theres more hacking to be done.
Cut off the oe hitch, cut off the oe x member/rear bumper, hacked about 3 inches off the frame, relocated the reciever to frame level, bolted it all in for now. I plan to incorporate some kind of tow hooks at the frame horns, and do some kind of wrap around corners. Oh and Im looking in to cutting the rear 1/4's up at the tape line in one of the pics. weeeeeeeeeeee! Feel free to critique. D
#42 |
critter size!
Sas'd 94 Pickup Status= Installed Sliders, Trying to Borrow A Tube Bender!!!! WARN M8000, 3.0L, 35X13.5X15RT Toyo MT's, 5.7R&P, Rear 4" LowRange Leafs with 8" shackles, LockRight, Front 4" front springs 6" Shackles, Spooled, 30Spline Chromoloys. I Have Gone To Find Myself, If I Dont Return Before I Get Back, Please Leave Me Here |
#43 |
lol
19 inch lift is next..... D
2000 taco 4x4 ext. cab v6 manual. ap sliders, u bolt flip, ome 882/dakar/c. shocks/greaseable shackles, ss brk lines, bud built skid and belly pan, ext diff brthr, dp, 33x10.5x15 bfg mt's on stock alloys, 04 trd e lok rear axle, demello hybrid r bumper and bed bar, custom front bumper/rear diff skid,heated drivers seat. 93 FZJ80 Aussie locked, body worked, and welded on. |
#44 |
More hacking.
Frame is boxed w 1/4", tow pts welded to frame and frame caps. Ugly but I have a lil more clearance, a reciever, and the base for some wing type things. Still have to decide what to do w the 1/4's... D
2000 taco 4x4 ext. cab v6 manual. ap sliders, u bolt flip, ome 882/dakar/c. shocks/greaseable shackles, ss brk lines, bud built skid and belly pan, ext diff brthr, dp, 33x10.5x15 bfg mt's on stock alloys, 04 trd e lok rear axle, demello hybrid r bumper and bed bar, custom front bumper/rear diff skid,heated drivers seat. 93 FZJ80 Aussie locked, body worked, and welded on. Last edited by darwink1; 08-20-2009 at 07:09 PM. |
#45 |
dude nice work. looks fun!
03 Taco Xtra Cab TRD V6 5spd, SAW 2.0s, aal, Downey Shackles, 255/85/16 Cooper S/Ts, CBI wrap around tube rear bumper, CBI sliders, CBI plate front bumper, Hella 500ffs with 100w bulbs, ARE topper, bed liner. |
#46 |
itneedsmorebandwidth!
95 4Runner 6cyl 3.0 - bought 4/1/08 and is work in progress... bj spacers, T-Bar adjustments, 4" ProComp lift coils, 31"x10.50"xR15 Cooper Discoverer STT, ProComp ES3000 shocks, blinker/running light mod, front & rear bumpers, energy suspension LCA bushings, sliders to come: lock-right, 33's |
#47 |
Updated pics.
Added a stinger to the front w some lights, built a rear bumper, more body work, and some new meats. ![]() ![]() ![]() D
#48 |
Front and rear bumpers are looking good!
#49 |
what size tires you got there?
#50 |
285 75 15 goodyear duratracks. they ride very nice and are day/night compared to the old 265's that came with the van.
D
#51 |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Finally broke somethin | tlh89 | General Discussions | 25 | 04-16-2009 03:58 AM |
| Cool shop found in Portland | SashimiTaco | Fabrication/Mods | 2 | 11-27-2007 11:06 AM |
| Cool thread I found while searching | 4x4offroader | Off Topic | 22 | 01-31-2006 04:01 PM |
| found a cool article on coilover comparison.... | The Dude | Suspension | 2 | 01-23-2006 10:13 PM |
| buddy found 81 toy 4x4 | captsurf | Eastern Region | 18 | 01-11-2006 01:40 PM |
