I'm starting my conversion. WooHoo!
Today I installed my transfercase. Removing the 2wd tranny to swap out the output shaft. ![]() ![]() Bellhousing and pump removed ![]() some internal parts ![]() removing valvebody ![]() ![]() without VB ![]() removing snap ring from output shaft ![]() all this work just to swap out this shaft ![]() 2wd shaft ![]() 4wd shaft and VB reinstalled ![]() transfercase adapter thingy ![]() RAN OUT OF SPACE!!!
Chris 2003 Tacoma dblcab TRD Pre-Runner
#2 |
Continuation
transfercase and adapter ![]() trany and transfercase bolted together and ready for install ![]() almost done ![]() 4wd mount and 30" center driveshaft ![]() finished with all the work from underneath ![]() I started at 2pm and finished at 9:30pm. Drove it home, but still need to finish up the inside (shifter). The only problem I ran into was the speed sensor, so I will be driving around with a handheld GPS for a speedometer till I find one. Step 2 will be spindles and diff. Need spindles with manual hubs. Step 3 wiring everything up, and wheeling it!
Awesome! Good Luck with it!
-Chris![]() 5 Toy Family. '99 Taco V6 4x4 5 speed, 35s, Tundra Brakes, 1/2 locked, high clearance bumpers, flat skids, Bilstein/ Eibach/ Alcan suspension, too many lights, Loud music and exhaust, OBA, couple batteries. Facebook |
#4 |
![]() Join Date: Sep 2006
CColin- Great WORK!! Nice pics and write up as well. I'm looking to do the same with my truck soon.
Wanted to ask where you found your transfer case? And where did you pic up the 4WD shaft? I've been looking for about 6 months for the right one for my 04 V6... I can't seem to get it though. I work overseas a lot so unable to actually go and scout the junk yards regularly. Good luck with the build. Keep us POSTED!!!
Boz Owner & Founder B Industries, LLC B.tactical (Custom gun sales / Training & Instruction) B.fit (Personal fitness on a new level) 2004 Harley Davidson FLHPI Road King (Police Edition) 2004 Tacoma TRD w/some extras... My Truck Build Up... Click here and enjoy! 4x4 Conversion Thread |
#5 | |
I bought a whole setup (motor, trans, transercase) about 2 yrs ago to swap out the motor on my 94, ended up just fixin my motor, and left the whole setup in the garage. Then I bought my 03 last year and figured I should make it 4wd since All I needed was to find the stuff for the front (diff, spindles with hubs). I had a 4wd shaft but after I measured everything it was 2" short, so I posted up on here, and luckily someone had one. Try to pm Jomentum, he might be able to help you.
#6 | |
http://www.ttora.com/forum/showthread.php?t=63114 as for speed sensor you can just make an extention for your stock one...... prerunner's is located on the tail housing of the transmission as aposed to the 4x4 which is on the out put of the transfercase..... just make and extension and it will be fine... the other 3 wires you have on the transfercase are there just for position sensors, we never wired mine in when we put the 4x4 stuff under my prerunner. keep up the good work man, its well worth it in the end!!!!
Matt Young 2002 Tacoma DoubleCab SR5 TRD 4x4 PreRunner Mods:saw 2.0's w/o sway-bar*deaver 3 leaf aal w/ bilstein 5100*4.56 yukon gears front/rear*manual aisin hubs up front*factory trd locker in rear*35x12.5x15 BFG MT's on 15x8 Steelies*flowmaster super 40 single in/dual out dumped at the axle*4xinnovations 80" long sliders*4xinnovations front tube bumper w/ stinger*mossyrocks fab bed-bar*1" roger brown body lift*budbuilt front skid plate my 4x4 conversion!!! myspace |
#7 |
SoCal Vice Pres.
I think he was asking about the 4WD output shaft in the transmission, not the D-shaft.
~Jamie 2000 Tacoma TRD 4WD PreRunner Supercharged. Locked. Armored. Mountain: She can crawl it. Ass: She can haul it. "Roads? Where we're going we don't need . . . roads." ~Dr. Emmett L. Brown My Rig My Trailer 4xInnovations |
#8 | ||
SoCal Chapter President
![]() Join Date: Jul 2006
Here is the prerunner speed sensor ![]() Here is the 4wd speed sensor ![]() But, Matt is right about the speed sensor wiring needing extending. As for the three position sensors/switches. On the drivers side, the forward switch is the Transfer L4 Position switch. Basically, all this does is to allow the TRD e-locker engage only when the transfer case is in 4 low. The rearward switch is the Transfer Neutral Position switch. This prevents the automatic tranny from shifting into Park if the tcase is in Neutral. On the passenger side, the Transfer 4wd Position switch. When the transfer case is in a 4wd ( Hi or Low) condition, this switch energizes the ADD to engage the front axles/CV's. Someone correct me if I'm wrong.... I like that you took a different approach than just swapping in a A340F tranny with matching tcase. As I progressed through my swap, I often wondered about just replacing the rear output shaft on my A340E transmission. Are you going with manual or ADD front end? Keep up the work and keep us posted! Rick
2010 TTORA Takeover - Big Bear, CA SoCal TTORA Forum SoCal TTORA Website |
#9 | |
I had a tranny with cable, but my truck doesnt use cable, so went ahead and changed shafts. We have a transmission shop so it's just a everyday thing to us.
#10 |
I got a donor 4wd trans.
#11 |
yeah i completly mis-read that.... my bad.
#12 |
Thanks for the info to all.
I have read Jamie's thread before, good stuff too. CColin- if your able to keep taking pics of your work in progress please do. Even if you don't post them I'd like to ask if you'd be willing to email them to me. I find pics great for references when trying to do my work. Thanks
#13 | |
pm me if I can help you in any way.
#14 | |
I just got laid... off.
![]() Join Date: Dec 2004
05' TRD 4x4(gas guzzler) 85 4Runner 3RZ power! For sale! 85' 4Runner Build Up Thread New Forum Rule When in doubt, bring Wes' name into the argument to turn attention from yourself. Not sure of what to post b/c you're an attention posting whore? Call Wes' intelligence into question... Always good for a little snicker. And if you act fast enough, it's guaranteed to make you feel better about YOU. |
#15 |
Installed the shifter today!
removing the shifter ![]() ![]() Had to trim floor ![]() transfercase shifter installed ![]() shifter installed - I used a 4wd base and swapped out the stuff on the shifter ![]() trim installed - I still need to bend the lever a bit, pops out of low. ![]() testing out 2wd low ![]() ![]() finished inside look ![]() IT'S ALMOST 4WD
#16 |
Wslytoy- thanks for that info.
#17 | |
#18 |
Sorry about that I moved the pics into a different file and it messed up the link.
#19 |
might have covered this before but........................ why does your transfercase shifter stick so far out?
#20 |
the shifter was off a truck with body lift.
#21 |
#22 |
3" I think
I think the height is good but I just have to heat it up and reshape it.
#23 |
swap looks good so far, good luck with the rest of it (esp with this tropical storm headed this way).
wes
06 DCab Prerunner, TRD Sport, V6, Auto |
#24 |
Thanks
#25 |
Looks great colin! I considered the swap but kept having setbacks, so I decided to hell with it and I'll buy a SA rig later.
SURF FUCKINGDRUNK ƃɐqǝɥɔnop ɐ sı ʎʇıɹnd |
#26 | |
![]() Tried three different Toyota Parts departments w/o any luck looking for the ADD control relay. TRDParts4U and I must have got off on the 'wrong foot' Champion Toyota informed me that I'd have to wait for Shannon to get back Titus-Will had three different parts guys try to help me and none of them could even identify that a ADD Control Relay existed in the 4x4 Tacoma Jonathan took the same information I sent to all three Toyota parts departments and found the relay on a vehicle in his inventory. I should have the relay by this weekend..... /hijack off Rick Made any progress Colin? |
#27 | |
should be getting hubs today.
#28 |
hardcore dude
Sweet. When I did the swap My UCA's were attached to my spindles, so I just put them on too to avoid dealign with balljoints.
That part (I already had the diff in) probably only took me 3-4 hours solo and having never done it before. I did already have the spindles + hubs cleaned up. Get some FSM diagrams and make sure you have the washers, clips and whatever though. I had to order them from Shannon cause the dealer in town couldnt find them. Only was like 12 bucks.
http://s116.photobucket.com/albums/o22/tacoma_kyle/ I now need a front drive line for use with manual hubs. ADD hubs are different sorry. If you have one PM me. |
#29 | |
I rebuilt my diff and is ready to go in, I just dont want to install it till I have everything else ready, dont want dirt to get into the diff. What company does Shannon work for?
#30 |
| Thread | Thread Starter | Forum | Replies | Last Post |
| IFS Conversion | Taco05prerunner | Late Tacoma Tech | 2 | 11-28-2007 02:16 PM |
| 4x4 Conversion and Manual Conversion? | notw53 | Early Tacoma Tech | 5 | 11-20-2007 11:50 AM |
| ORS Tacoma SAS /79-85 3.4L Conversion Oil Pan Conversion | ORS | Sponsors Products | 0 | 09-26-2007 05:42 PM |
| Hub Conversion | RCBS | Toyota Truck & 4Runner Tech | 7 | 02-08-2007 08:18 PM |
| s10 conversion | Ripcurlsurfin96 | Off Topic | 13 | 06-04-2005 04:56 AM |
