Welcome to the TTORA Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
Truck: 2007 Access Cab PreRunner TRD 4.0, ~40,000 mi.
Problem: Little Bit too much body roll in the corners. I've got a buddy who has a Titan. I follow him around the corners on curvy roads when we go dirt bike riding sometimes, and he likes to do 70 mph around those corners! He's got a lot more rubber on the road, and more street-oriented tires (BFG Long Trails). (I have the stock Rugged Trails on mine.) Not to mention, he's got quite a bit more HP & Torque! I realize that my truck has off-road suspension, and I do love the ride when I'm going through fields and down bumpy gravel roads, etc. But what can I do to reduce on-pavement body roll in the twisty stuff? Overall, I love the handling of my truck - I have had it on Deal's Gap even, and I think it steers like a sports car. This is my only real complaint (other than the fact that the Japanese don't know how to build an automatic transmission, ha ha). What's the solution, fellas? John Memphis |
#2 | |
Not much you really can do, I guess you could get a beefier sway bar, widden the stance of the truck somehow IE wheel spacers or rims with less back spacing, and bilstein 5100 shocks at all 4 corners with the front set to zero.
2006 Tacoma X-cab 4x4 OME coils and 255s General Grabbers now featuring toytec spacers, tube doors, and now powertrax locker . Still trying to fit 35s ![]() 1992 Chevy 2wd - 5in lift 33s locked now the tow rig |
#3 |
If you really whant to take body roll out, install a rear sway-bar. You will lose offroadability, but that is the price you pay.
2008 four wheel drive X-cab Tacoma, with Fox shocks on all four, 3'' suspension lift, All-Pro UCAs, Borla cat-back, URD Y pipe, ARB Bull Bar, and a Ramsey 9500 winch. |
#4 |
Air Bags in the rear help alot. I don't rock crawl mine, I use it to tow and drive in the dunes where max travel is not really needed (no I'm not prerunning it thru the whoops either). 15 psi in the bags unloaded and it will not sway nearly as bad. If your really going to drive it hard pump them up to 40psi with no load and it really stiffens up the chassis, but you will have a little bit of a stink bug stance.
#5 |
I don't take my PreRunner off road; 99% is on-highway driving.
The worst terrain my truck will ever see will be going down a rough, unimproved road while trucking dirt bikes to the trail head. That said, I don't want to lose suspension travel... I am just hoping to be able to find a solution to the (what I consider to be) excessive body roll when I'm on a curvy road. I am hoping to be able to find some aftermarket, adjustable shocks, or some other bolt-on solution that won't require extensive modifications to the truck. Other than that small niggle, I love the truck, and I love yall's forum - it's a great source for info! John |
#6 |
Does your truck qualify for the rear leaf tsb? I noticed a huge improvement in body roll after getting mine done. Much firmer ride, not harsh rather like the difference b/w and accord and a jetta.
#7 | ||
Bovine Scatologist
![]() Join Date: Dec 2004
Add a rear SB with quick disconnects. There are several threads about them on CT.
Inchworm Rock Walkin' Gear |
#8 |
I've got the same issue going on right now on my 99 prerunner.
Do you have a canopy? Do you have extra weight beyond factory on the front end? Is your front differential dropped? Right now I am upgrading to Eibach 700lb 14" coils and adding a rear sway, I will let you know how it works out. |
#9 |
The problem is you have a Tacoma and its not made for going around corners at 70MPH, get a sports car if you are going to do that kind of stuff, hell go find a track.
- Richard |
#10 |
Last I checked a "Titan" is also a truck, they are made by Nissan. And 70mph is pretty fast for a corner in anything, i'm sure he meant a bend.
#11 |
Yeah we know about those gas sucking Titans, his buddy most likely was just trying to show off what the truck can do. Sorry but thats not using any common sense! I hope he gets pulled over one day and gets his truck impounded... it'll teach him a lesson
- Richard |
#12 | ||
#13 |
I have no issues against anyone... Just trying to tell the truth that trucks are not built for high speed corners thats all
- Richard |
#14 | |||
Bovine Scatologist
#15 |
Bingo. I disagree about loosing offroadability though. He's got a 2wd, he's probably not going to be rock crawling or mud bogging anyway. For anything else it will be just fine.
08 DC LB sport - Bilstein 5100s, Camburg UCAs, TSB leaves, N-fab light bar, Kragen 7" HIDs, Garmin GPSmap 60Csx |
#16 | ||
Bovine Scatologist
the rear SB can be fitted with quick disconnects. Mine works great.
| Sponsored Links |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| body roll please help!!! | numbnutz | Early Tacoma Tech | 32 | 07-06-2009 12:35 PM |
| 03-04 Prerunner auto trans 832 miles, IPT Valve body | Blone | Parts/Electronics/Wheels & Tires For Sale | 3 | 03-18-2008 02:52 PM |
| First roll-over and body damage | lvanst | General Discussions | 4 | 01-20-2008 07:22 AM |
| Prerunner stock leif pack (01-04 extended cab body style) | Chris D. | Wanted | 10 | 11-23-2006 12:09 AM |
| Body Lift, 33” tires, Body Mounts, 2.7L supercharger, Header and LOTS MORE! | Supercharged 2.7L | Early Tacoma Tech | 4 | 09-20-2005 11:25 AM |
