Go Back   TTORA Forum > General Tech > Interior/Electrical/Electronics
Old 11-03-2009, 08:53 PM   #1
fcaw11
Default DieHard Platinum Group 65 Battery
05+ TACO Prerunner
Wanted to share my installation of a DieHard Platinum Group 65 AGM battery. Which many claim to be a private label Odyssey PC1750 made by EnerSys.
This is the largest AGM battery Sears sells with 48 month free replacement, then 52 month prorated warranty.
930 CCA / OEM Toyota 710 CCA
135 min reserve / OEM Toyota 165min reserve claimed(more like 70 minutes)
claimed weight 60lbs. / ACTUAL weight 53.5lbs / OEM Toyota Group 27F 49lbs.
At first, it appeared the positive battery cable to the fuse box & ground cable would need to be lengthened. Load and behold, such measures were not necessary. There are 2 ground locations on the right side of the battery. Just swap locations. Now, the ground for the fuse box (two white wires w/black stripe) will need more slack. Open the wire loom by removing the electrical tape. Pull until desired length is reached. Then using new electrical tape, re-seal wire loom. I also used 3/8" heat shrink tube on the newly exposed two white wires w/black stripe.
Install battery. The ground cable fits because a Group 65 battery is 1 3/8" shorter than a Group 27. I used an aluminum battery tie down & fabricated a rear hook(Home Depot). The front hook is OEM Toyota.
battery weight<p>
<br>ground location swapped<p>
fcaw11 is offline   Reply With Quote
Old 11-03-2009, 09:07 PM   #2
TacoDell
Fawking Fly's
TacoDell's Avatar
that's purdy...
But I hope you don't wheel it, with that simple tension plate hold down !?
that shit will move...
'00 Taco SR5 V6, 5-SP, 4X, and some extras...
My Garage
TacoDell is online now   Reply With Quote
Old 11-03-2009, 10:08 PM   #3
tacotoy
Dun DUn DUN!
its still a wet battery right??? or does it have some sort of mat or other....?
99 Taco with 5 inches of lift and some toys...
tacotoy is offline   Reply With Quote
Old 11-03-2009, 10:11 PM   #4
TacoDell
Fawking Fly's
TacoDell's Avatar
AGM... an Odyssey in sears skin... they say.
My Garage
Old 11-04-2009, 03:38 PM   #5
Volcom
Volcom's Avatar
Originally Posted by TacoDell View Post
that's purdy...
Any threads or pics of how to hold a battery down in a wheeled rig? I've got the same tension plate hold down and my battery moves around quite a bit.
Addicted Off Road
Originally Posted by poorboyota26 View Post
Yeah it needs more troyangulation
Volcom is offline   Reply With Quote
Old 11-04-2009, 03:43 PM   #6
4xClover
4xClover's Avatar
First...search!
Second...Yes, something like this is a good start!
http://www.ballisticfabrication.com/...x-_p_1673.html
'98 SAS on 37's
4xClover is offline   Reply With Quote
DieHard Platinum mounting bracket D DUBersons Interior/Electrical/Electronics 1 10-26-2008 10:19 PM
Group 27F battery Switch Classifieds 3 04-30-2008 10:28 PM
skyjacker Platinum Series 04RedLobster Suspension 4 04-21-2006 08:05 PM
No Platinum Plugs?? Why Not? Beave Early Tacoma Tech 12 01-28-2005 09:35 AM
