Go Back   TTORA Forum > General Tech > Suspension
Old 11-07-2009, 08:34 AM   #1
davidc21a
Default Heavy Shake and Vibration plus 55+ on Freeway
Hi guys, wanted to know if anybody could offer some knowledge on this issue. I have 02 Prerunner with the 6" Fabtech setup. When i bought the truck with this setup, it ran fine. Now after a couple of months, whenever i drive it on the freeway or streets i get very hard and bad shake (like i'm on a rollercoaster) with heavy vibration when going 55+ mph. I went ahead and swapped the front struts and coils with a some radflo 2.0 coilovers and it didn't help with this issue. Can anybody offer and ideas? I took it to the dealer and they weren't any help at all, they said the culprit was the my 33" wheels..
davidc21a is offline   Reply With Quote
Old 11-07-2009, 11:45 AM   #2
NAYLOR
NAYLOR's Avatar
33" wheels? Have you checked if you tires are balanced? Alignment?
2003 Tacoma - Supercharger - URD mods - Icons
NAYLOR is offline   Reply With Quote
Old 11-07-2009, 12:20 PM   #3
davidc21a
naylor, thanks for the feedback. That's the first thing i'm going to check on monday
Old 11-08-2009, 07:48 PM   #4
foxgtr16
check out the u joint. mine had some real bad vibration problem and it was eating up the wheel bearings also. once i got i replaced its been fine.
foxgtr16 is online now   Reply With Quote
Old 11-08-2009, 10:42 PM   #5
hrtbrk1
x2 my guess is wheel bearings
It'll ride
99' stocko taco sittin on 31x10.5 BFG Mall Terrains.
hrtbrk1 is offline   Reply With Quote
Old 11-09-2009, 01:20 AM   #6
obz
start w/ the cheapest, wheel balance or alignment, or u joint or wheel bearing. had the same problem and turned out the two front tires were like 2 oz out of balance, every things been great since, going on 3500 mi. since wheel balancing.
obz is offline   Reply With Quote
Nesika Bay Heavy Tactical 308 **PIC HEAVY** ocherp Miscellaneous Stuff For Sale 3 01-14-2009 01:47 AM
Towing with a 3.4 O.D. on or off on Freeway? S/CTaco Newbie Tech 3 08-19-2008 06:35 PM
rear end shake/vibration Landbruiser Solid Axle Swap Tech 33 09-10-2007 10:22 PM
Bad Smell on Freeway..? Toyota00 Early Tacoma Tech 21 12-14-2006 05:48 PM
stalled on the freeway spraymaster6000 Newbie Tech 18 03-26-2006 06:04 PM
