Go Back   TTORA Forum > General Tech > T-100 & Tundra Tech
Old 11-07-2009, 10:19 AM   #1
scottq60
scottq60's Avatar
Default Looking at an 01 Tundra TRD
A guy at work is selling his 01 Tundra ext. cab SR5 TRD - V8, auto, pretty much all the bells/whistles I believe. Looks to be in EXCEPTIONAL condition with no accidents/paint work. He bought it from the original owner at 60k.
It has 117k miles on it and has a matching fiberglass camper shell and Rhino bed liner.
He's asking $8800...NADA shows avg. retail at just over $11k.
Any weak points, other than brakes that I read about? Is the auto tranny an issue? Does the V8 have a timing belt???
It appears to be bone-stock.
Scott
97 Taco
standard cab SX 4x4
4cyl/5spd
manual hubs
scottq60 is offline   Reply With Quote
Old 11-07-2009, 11:41 AM   #2
T_Dunn
T_Dunn's Avatar
Send a message via AIM to T_Dunn
Scott
Yes the V8 has a timing belt that should have been changed I believe around 90,000 miles but don't qoute me on the mileage interval. See if the tranny and the axles have been serviced and when.The suspension(shocks) should be starting to show some serious wear if they haven't been replaced and check to see when the last time the spark plugs were replaced too.
01' Tundra SR5 TRD Access Cab 4X4
91' Tercel DX "BEATER"
98' Tacoma SR5 Extended Cab 2.7L 5 speed
Bought By Toyota!!
Originally Posted by T_Dunn View Post
TJ Says, "Fuck Chevy's they suck."
T_Dunn is offline   Reply With Quote
Old 11-07-2009, 04:22 PM   #3
scottq60
scottq60's Avatar
Excellent tips...thanks!
Current owner says:
Timing belt and water pump changed at 95k
shocks - original
tranny was changed at 60k
spark plugs - 95k
97 Taco
standard cab SX 4x4
4cyl/5spd
manual hubs
Old 11-10-2009, 08:00 PM   #4
T_Dunn
T_Dunn's Avatar
Current owner says:
shocks - original
spark plugs - 95k
sounds like it was pretty well maintained the last thing I would look at is the crossmember in front of the spare tire and if it has a plastic bedliner lift it up and shine a flashlight in there to see if there is any severe rust in the bed.
Bought By Toyota!!
Old 11-11-2009, 09:06 AM   #5
devinsixtyseven
devinsixtyseven's Avatar
Check for any major frame rot. If you find none, or only the sort of thing a wire wheel and Rust Reformer (by Rustoleum) will address, BUY BUY BUY.
I'm at 150K on an 00...plan on swapping the starter in the next year or two, it'll be ready before 150K most likely. Don't worry about the brakes, learn good braking habits, or learn good braking habits and sell the old calipers to the Tacoma guys and get the TSB calipers. I'm still on the original calipers.
Upgrade the shocks. The best solution for an everyday truck is a set of Bilstein 5100s...not expensive, good performers. The shocks on the truck now might still be ok, but they're probably getting bouncy...also the OEM valving, even on the TRD version, was pretty soft...dunno if that's what you want or not.
Originally Posted by BOVADS
link it, build it at full stuff and go from there
"Tonight, you are going to hear...music you've never heard before. Tonight...you are going to hear...the most cantankerous, poisonous, roughneck dubplates ya ever HEARD!"
devinsixtyseven is offline   Reply With Quote
Old 11-11-2009, 01:07 PM   #6
TacoManny98
TacoManny98's Avatar
Send a message via Yahoo to TacoManny98
Still on my oringinal calipers also but plan to change to the TSB/Newer calipers & rotors before i give the truck to my daughter
1998 Taco Ext. Cab-Wrecked Trail Rig
TC 5" lift, Fabtech C/O, Alcan Leafs, DS 1.5 Shackle,More
4.88 Gears, F/R Loc-rites, CBI Amor Package,Tube Doors, Snorkle, + More
2002 Tundra AC V8 4x4 - Tow/Daughter's Rig
3" T/T Coilovers, TG Sliders, 1"B.L, ARB winch Bumper, MM winch
http://www.tacomaterritory.com/forum...84#post1783584
1985 4Runner - Project Retro
2" lift, Brush Guard, Soft top, 32" M/T's on Black RC
In the works for a full retro back to mint condtion
TacoManny98 is offline   Reply With Quote
Old 11-11-2009, 02:17 PM   #7
devinsixtyseven
A tip that might save you a few bucks...you can use the same rotors, if they're in good shape. Just buy the same kind of pads you were running on the original calipers, just the correct part number (ie shape) for the new calipers.
Make sure your daughter learns good braking habits too . She'll be driving better than most guys I know ...but really, it'll help the brakes last longer & be there when they're needed most.
-Sean
Tundra TRD Bilstien struts and OEM tundra strut plates 02taco4x4 Parts/Electronics/Wheels & Tires For Sale 0 10-29-2008 03:44 PM
01 tundra v8 4x4 for 10k. Should I? rockstar4christ T-100 & Tundra Tech 17 02-22-2008 09:17 PM
New Tundra Specs Posted - Tundra Crew Max CMB1998 T-100 & Tundra Tech 9 01-10-2007 12:07 AM
My new Tundra! Froggygirl T-100 & Tundra Tech 6 06-26-2006 01:32 PM
