Welcome to the TTORA Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#31 | |
Im a steel fabricator by profession, we run our gas at 35psi constantly(unless I have a fan on then its more). I keep the nozzle close to the weld and make sure to push the weld. Using a welding curtain to block wind is usually a good idea as well.
Dustin 1985 Death Runner 4x4 Built 155 hp 22r Straight axle ![]() Gone-1996 Taco 4x4 http://www.cardomain.com/ride/2300853 |
#32 | |
NorCal Vice Prez
Running the tip of the nozzle back towards the weld has the shield gas shield the weld. I've never had to run above 30cfm for welding, even outdoors.
Hi, my name is Phill, above are things I say
#33 |
Fabricator smabricator. I weld outdoors, 25psi, torch pointing the direction of travel. use as much heat and wire as possible without undercutting.
#34 | |
Push or drag depending on how you need to control the puddle and the depth of penetration. I usually drag, unless it's just not possible to get a stable angle with the gun to finish the weld by dragging. But theory & practice are so different
...know what I need to do, screw it up anyway.If I'm dragging the gun, I can easily put the arc right down in the root, not so easy to do that with a push. Use the two techniques similar to how you use uphill vs downhill MIG.
#35 | |
#36 |
some regulators do read in psi on both the tank side and on the out flow side. It is simply giving an outflow pressure read. Cfm is volume from a certain pressure, psi is a pressure at a certain volume. Two different way to meter flow.
#37 | |
What is on a welding tank is a combination pressure regulator and flow meter and only the meter is adjustable. Flow rate through the meter is a measure through a orifice and the pressure differential caused by the change in area is correlated to flow rate. The regulator or tank side is set at a fixed pressure as that is what the flow meter is calibrated for. The gauge you see on the tank side tells you whats remaining in the tank. |
#38 |
30-35 CFM is the correct setting, you can also try using different mixes of gas sometimes you need different gas for varying material.
88 $runner RIP, 99 TRD xtra cab 5spd, 4:10's locked, line-x, OME set up, Volant air intake, LCE shifter, Flowmaster super 40, "BO" door code is bs |
#39 |
i've never seen a regulator that reads PSI that doesn't exsist, they only read CFM for your gas flow.
#40 |
Is welding easy to learn? Most people say it's pretty easy! At one time I was going to take 2 classes, gas welding and wire feeding, but decided to bail because of school... I regret dropping those classes... Wish I had gone to those classes!
16X8 black steel wheels with toyo tires. 4" deckplate mod with AirRaid intake tube. TRD headers, Flowmaster super 40 muffler. TRD rear axle with 4:10 gears Future mods: Icon CO's, Icon resi shocks TC UCA's, Deaver's leaf spring kit |
#41 | |
haha! despite what all the big shot fabricators on here may have you believing, welding is relatively easy skill to learn . it is just making those welds look nice is what takes practice, practice, practice. the hardest part is keeping all the different wires, and gases and other shit straight. if you are really interested head down to your local community college, they should have a beginners welding class you can take. probably be a mix of stick electrode and MIG (wire). (i weld/fabricate 10hrs a day, sometimes 6 days a week. and i still learn new shit everyday)
'06 Tacoma 2.7l 4x4 access cab sr5 265/75/16 Goodyear duratrac's w/black raceline renegades OME 885/dakars |
#42 |
#43 | |
I mostly agree w/Caddy...welding is easy to learn for some people.
If you have a good work ethic, prefer results to cosmetics, are detail- and process-oriented, then you have the potential to be a very good welder. If you're laying a bead thinking about how it looks, or think it's easy before you've spent a year practicing, don't want to deal with little details, and don't care to learn the steps to take to lay a good bead without piddling along through it like they do on the chopper shows, then you will never be a good welder. Unfortunately I firmly believe that most people these days fall in the latter group, hence the rise of idiotic cosmetics-first MIG welding techniques, pride taken in booger welds, and all the leg-humping from a lot of people on 4WD forums whenever they see anyone posting anything with melted metal on it, regardless how dubious or awful the welds may be. Welding takes patience, thought, and common sense, all of which seem to be in short supply. If you possess those traits and wish to apply them to welding, then you have the potential to be a good welder. If not, and you honestly need to establish that for yourself, then you are setting yourself up for several thousand dollars' worth of mistakes. -Sean
#44 | |||
Bovine Scatologist
![]() Join Date: Dec 2004
Inchworm Rock Walkin' Gear |
#45 |
#46 |
#47 | |
If you have an older lower end miller/lincoln package setup then they came with what was essentially a pressure regulator with a fixed calibrated orifice and you did the flow rate conversion in your head or with tables. The problem with that is, just saying XX psi does no one any good as you need to know what gas youre running and the orifice size attached to the regulator. |
#48 | |
#49 |
yeah I was going to take those classes at a local community college. Tuition is a lot of money, the college wants an arm and a leg for classes and then you have to buy all your gear. It sucks! Maybe I should go out and buy a wire feeder and teach myself to weld. Like you said it's prett easy to learn!
#50 | |
#51 |
Yeah its called porosity...Its caused by conamiation improper shielding...
#52 | |
Ive never actually heard of a millermatic 220 to be honest, ive heard of the 200, 210, 250, 211, 215 etc. But if it comes standard with a complete package and is not available as a stand alone machine, that usually indicates its on the lower end of the miller line up and marketed toward the home garage, light duty fabricator and beginner with a lower duty cycle. I am not saying its a bad unit at all, i only buy miller when i shop for a welder and all of their units are built well and built to last. But if you bought yours in 2004 and it does not have a CFM reading or a fixed orifice pressure regulator you are using the wrong type of gauge. But if youre just using one type of gas mix and dont vary much in steel or environment it dosent really matter as you dont need to adjust much as far as the gas flow is concerned. |
#53 | ||
Gloves 20$ Cheap helmet 40$ (non auto) Brush 10$ Hammer 5$ Sleeves 5$ Cap 3$ Plus jeans, boots and a couple old t-shirts, sweatshirts, or whatever. Make it work on a low budget and keep in mind you're probably in the same boat as everyone else in the class as far as experience and budget. Don't buy a welder until you've taken some classes and have an idea whether you'll be any good at it or not. If it works out, save about a grand and a half for a welder and other gear, and get something good. Fabrication is a bit of a commitment. ...Though if you decide to put the torch down someday, the welder won't get pissy at you and leave with half your shit ...-Sean
#54 | |
SAY "CFM" .
#55 |
I would say its probably from wind? This happens to me all the time when I am welding outside, it will be fine but the end of the weld will do that from the slight breeze
#56 |
I took a couple of classes, and found myself skipping class, so I could go work in my own garage. I got a lot more practice using my own equipment. The classes I took consisted of a brief demonstration and then being turned loose to work on your own. Usually, you had to wait in line to get on a welder. I think it's quite possible to teach yourself to mig weld using books and maybe a video.
One thing I learned is that you spend the vast majority of your time preparing to weld. Getting everything fit and jigged up is more than half the battle. |
#57 |
this makes a big difference. it seems everybody always wants to go and buy the $300+ speedglass for there first hood. you do NOT need an auto hood.
i started out with a $30 huntsman. they're heavy and ugly, but hey, they work and when you are just learning that's all that matters. sure, now i have a speedglass, and i would never go back to a non-auto. but guess what........ that old huntsman still has a place in my tool box, just in case my fancy hood goes tits up.(although i have bounced that thing off the concrete so many times i am beginning to think it is damn near indestructable )....this thread has gone waaaaaayyyyy off topic
#58 | |
CO Chapter Prez
Be sure to check your local welding supply place for classes too. General Air here in Denver holds them - free if you buy a welder.
President - CO Chapter Founding President - OH Chapter '93 4Runner lockers, armor, tcases, & stuff '96 Impala SS - my own personal cop car Check out pix at www.4wheelingoh.shutterfly.com/action |
#59 | ||
#60 |
when i needed to weld axle arm of my car, i called a professional. he had all the machine with him to do the best work for me. not much expensive too
| Sponsored Links |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Welding question | Kaistie | Tech/Tricks | 40 | 08-14-2009 12:49 PM |
| Welding question | GodyillaTaco | Fabrication/Tools | 19 | 02-25-2009 12:11 AM |
| ECM and Welding question. | Wheelie_Pete | Early Tacoma Tech | 6 | 05-16-2007 04:26 PM |
| welding question | thehackman15 | Fabrication/Tools | 15 | 03-01-2007 08:05 PM |
| Basic arc welding question | vanguard | Fabrication/Tools | 22 | 11-10-2005 01:46 PM |
