Welcome to the TTORA Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
currently running 31" tires and would like to switch to 33. i have a 2003 tacoma mini 5lug i believe it has a 7.5 in the rear? looking to replace it with a differential that has a E-locker, and a better gear setup for my mini. any information would be appreciated, i dont care to much about the lug patterns, but would like to keep the E-brake. thanks!
#2 | |||
Bovine Scatologist
![]() Join Date: Dec 2004
Inchworm Rock Walkin' Gear |
#3 |
if i were to keep the 31" would 4.10 be good enough?
#4 | ||
Bovine Scatologist
#5 |
coo! sorry to bother, but would this work for my mini? is it hard to change swap it out, i have done it before on my mustang but never worked with leaf springs thanks hyten
http://cgi.ebay.com/ebaymotors/2003-...Q5fAccessories |
#6 | |||
Bovine Scatologist
as for adapting the axle... since you have a spring-under setup rather than the spring-over that the donor truck has you'll have to get and weld on the spring perches. There will be more info on this in the desert race forums since many of them do this swap. contact Drabnor for better info. Shock mounts will also have to be done, most likely but RJ will be able to help you with that.
#7 |
thanks a lot, pretty good with electronics so the e-locker shouldn't be a problem, but ill have to have someone weld those suckers on. im looking to buy the axle local maybe with a better price. but the locker is a must, i looked like a idiot last year in the mountains when my tires would spin in opposite directions when i hit a little ice "with chains".
#8 | |||
Bovine Scatologist
Open diff or LSD is best for that. I only use lockers in deep snow and then usually both front and rear.
#9 |
so do you think best bet sticking with the 7.5" and just regear with a lsd? this is my daily driver so i dont abuse it to much
#10 | |||
Bovine Scatologist
![]() I'd go for the elocker and just use it when needed.
#11 | ||
Bovine Scatologist
what year is your truck? '05+ minis already have the 8" rear...but with 5-lug axles.
#12 |
hey its a 2003, to be honest i really dont do much offroad, but when i take out my quad i like not getting stuck on a small aunt hill. this is my daily driver so i try not to beat it up to much.
#13 | ||
Bovine Scatologist
have you checked to see what gears are available for the rear 7.5" The CT guys should know more about it. If you can get gears for it along with a LSD it will be a lot better than what you have now.
#14 |
put a lockright in it for $200. in fact, i have one i could sell you.
#15 |
sounds good just might go that rout thanks. i have checked out the gear size before by checking the numbers on the door jam but i forgot
so i guess ill be regearing, and installing a lsd. do you guys know what kind of labor charges ill be looking at? im pretty mechanically incline, but i hear if they are not installed right they can cause problems later
#16 | |||
Bovine Scatologist
![]() First, find out what gears are even available for the rear 7.5"; that will determine tire size, frankly...if you stick with the 7.5". go with 4.88s for 33s regear cost: parts will be around $400 (gear set and master install kit), labor averages $250 for the setup if you hand the gear shop the 3rd member. Setting up gears is not for the novice and requires some special tools. But, if you have mad skills and the tools...or a friend that has them...it can be done by following one of the many online writeups. you can swap axle assemblies for a few hundred bucks more, run the OE 4.10s and 31" tires
| Sponsored Links |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Taccoma rear differential | ICEJON32 | Late Tacoma Tech | 20 | 12-11-2008 06:52 PM |
| WTB:'95 TRD Rear Differential 4:10 | trdcruizer | Wanted | 0 | 08-09-2007 05:00 PM |
| rear differential leaky? | raudybaugh | Newbie Tech | 8 | 04-09-2007 02:30 PM |
| Rear Differential | tacoma0309 | Newbie Tech | 5 | 07-26-2006 02:40 AM |
| HELP! Who knows the differece in the rear Differential?! HELP! | konrad | Early Tacoma Tech | 16 | 01-13-2005 09:55 AM |
