Toyota Territory Off-Roaders Association (TTORA)
Toyota Territory Off-Roaders AssociationToyota Territory Off-Roaders AssociationToyota Territory Off-Roaders Association
Sponsored Ad
Go Back   TTORA Forum > Rock Crawling Tech > Solid Axle Swap Parts Lists
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Welcome to the TTORA Forum forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact contact us.
Reply
Thread Tools Display Modes
Old 11-02-2009, 03:52 PM   #31
hytenor
Bovine Scatologist
hytenor's Avatar
Default
Originally Posted by FAUX X 4 View Post
If it aint locked....... it's broke!
not the truck, dummy...
Originally Posted by rojodiablo View Post
But my rear is pretty good, and I have a lot of droop, and a ton of flex.
Originally Posted by =ACID RAIN= View Post
Purrrty, =GAYR= and Cunting-Homo. What's next, Oppositegirl? 5peckers? mypapilloma? Hybendover? Toymasturbator? Mr Baloney?
'00 Excab Tacoma, 2.7, 5sp with a Bunch-o-mods
Inchworm Rock Walkin' Gear
hytenor is offline   Reply With Quote
Old 11-05-2009, 09:05 AM   #32
06silverback
Default
may have found an axle last night. its a HP44 with drum brakes, so its a pre-1977 axle. i believe its from a '73-'75 ford and i hope so, because i think those had the 1/2" thick axle tube. im researching the numbers stamped on the axle tube today to see what i can find out on it. the numbers are: 10 22 5B4 603689 8
2006 DC TRD, 6" ProComp Suspension lift, 35" BFG KM2's, Blackrock 909 wheels, 4.56's, All Pro Plate bumper, custom sliders with 15 degree kickout, AFE CAI, URD MAF calibration unit, factory E-locker in rear, FOA coilovers, Camburg UCA's, Rear Alcan's with flipped shackles and orbit eyes, custom tube bed, front ARB air locker ....contemplating SAS
06silverback is offline   Reply With Quote
Old 11-05-2009, 09:43 AM   #33
dyogim
dyogim's Avatar
Default
Looks to be from a 76 F150. Do a search on BOM 603689-8
Doing a search on dana's sight resulted in nothing. I'm surprised they do not have it listed in their docs. http://www2.dana.com/pdf/XGI.pdf
Mike
SFA '00 Toyota Tundra V8(#5)
dyogim.blogspot.com
dyogim is offline   Reply With Quote
Old 11-05-2009, 10:51 AM   #34
06silverback
Default
hell man, you got to it before i did. being at work sucks
wonder what the thickness is on the axle tube??? hopefully 3/8 or 1/2"
Old 11-05-2009, 12:09 PM   #35
hytenor
Bovine Scatologist
hytenor's Avatar
Default
3.5" tube = 1/2" wall
brakes can be swapped out for discs, I believe...you're gonna need flat top knuckles anyway.
Old 11-05-2009, 12:18 PM   #36
dyogim
dyogim's Avatar
Default
I'm at work.... LOL!!!
Mike
dyogim.blogspot.com
Old 11-05-2009, 12:35 PM   #37
06silverback
Default
i think the tube is only 2.75" diameter.....yeah, im planning on going to chevy flat top knuckles for hi-steer and running discs anyways. it was 66" WMS to WMS, so i dont think ill have to shorten it
Old 11-05-2009, 02:30 PM   #38
sprocketdog
sprocketdog's Avatar
Default
Well I finally got this axle out of the woods and into my garage but i am having a very hard time reading the BOM there is one number that I can barely read. But I am checking on spicer list and am coming up short. I believe the number is 610024 but there is no number listed. The bottom of the 4th number is the only thing I can read so it could be a 0,3,5,6,8,9 but when I research all of these in place of the 4th number it is not matching up. I know it is a ford axle because of the factory hubs. I dont know if it is a 44 or a 60 it seems pretty beefy.
sprocketdog is offline   Reply With Quote
Old 11-05-2009, 02:57 PM   #39
dyogim
dyogim's Avatar
Default
610024 is from a 77 F150.
Mike
dyogim.blogspot.com
Old 11-05-2009, 03:43 PM   #40
06silverback
Default
the axle tube on a 44 will be smaller than a 60 also. if the one i found is a 3/8" thick tube im going to make a truss similar to the TnT truss ive seen for it.
Old 11-05-2009, 03:54 PM   #41
hytenor
Bovine Scatologist
hytenor's Avatar
Default
.250 wall
3" is 3/8" wall.
Old 11-05-2009, 05:01 PM   #42
sprocketdog
Default
I started digging into this housing and found something the looks out of place. I was hoping some one could take a look at this and tell me if there was damage done? It looks to me like a chunk of material is missing. I dont know how since the race sits up against it.[ATTACH]Click image for larger version
Name:	D44 damage 003.jpg
Name:	D44 damage 002.jpg
Old 11-06-2009, 08:13 AM   #43
06silverback
Default
all the research i did last night says the '76 is a 2.75" diameter tube and is 3/8" thick on the f150 and 1/2" thick on the f250....unless that's wrong. it went thru all the years from about '71 on.
what do the edges of that chunk look like??? are they irregulary shaped like a chunk cracked and came out??
Old 11-06-2009, 09:38 AM   #44
Alan11116
"Terry Tate"
Alan11116's Avatar
Default
Alan1116: im contemplating an SAS for my 06 DC tacoma. have you had a ny breakage problems with your D44 HP???
sorry just saw this. mine isn't a HP but the only breakage I have had is a stock long side inner shaft. now I have chromo shafts and longfield joints.
Alan11116 is offline   Reply With Quote
Old 11-06-2009, 10:28 AM   #45
sprocketdog
Default
It is too hard to tell if it is a break it is a very clean one. The bottom alomost has a perfect semi cirle to it. I ran a smalll screw driver over it and you can feel the texture but ont the inside these diffs it has texture every where. I am wondering if I can just pool up some weld to fill it in.
Old 11-06-2009, 11:22 AM   #46
06silverback
Default
Alan: good option for me or not in your opinion???
Old 11-06-2009, 12:37 PM   #47
hytenor
Bovine Scatologist
hytenor's Avatar
Default
hmm, that sounds right...scratch my last...
Old 11-09-2009, 08:30 AM   #48
06silverback
Default
anyone know offhand who might carry a chromoly 30-spline stubb shaft for these axles?? the stock stubb shaft is a 19 spline i think....wanted to ask this before i picked the axle up in the next few days, 'cause i wanted to do this for strength. picking up some reid racing chevy flat top knuckles after this.
Old 11-09-2009, 11:50 AM   #49
hytenor
Bovine Scatologist
hytenor's Avatar
Default
someone had a pair in the fs section a while back.
Parts Mike can get anything.
Old 11-09-2009, 01:52 PM   #50
Deserttaco
www.deserttaco.com
Deserttaco's Avatar
Default
I doubt that that's damage... It has the same coloring as the rest of the inside of the housing. You need to check to see if it goes anywhere. Any Cracks around it? Any Chance you can get a closer pic with a little better lighting?
Regardless, I wouldn't fill it with weld... It'd difficult to weld to cast correctly, Unless you are a seasoned welder on Cast. I'd pour a little light oil down inside it, make sure it doesn't leak out the other side. If it doesn't. Run it as is. If it leaks, then you probably have other problems.
Deserttaco is offline   Reply With Quote
Old 11-12-2009, 08:11 AM   #51
06silverback
Default
started tearing down the axle last night....rusty bolts . anyways, it just so happens mine is a '76 with drum brakes and the brackets are welded on instead of cast into the axle housing, which is good because the '76's were thicker housings than the later ones. gonna start a thread maybe on the build-up of it for those that may think of doing the same later.
Old 11-12-2009, 10:11 AM   #52
dyogim
dyogim's Avatar
Default
My hp44 is from a 77 F150 and I started a build thread back in 08 here: http://www.ttora.com/forum/showthread.php?t=102259
It's not too detailed but, shows a pic of it pretty much complete and under the truck. I'm using Chevy outers and the WMS measurement was 65.75". With 2" spacers on each side, the overall WMS is 69.75".
I think I still have the TR and DL in the garage. It's set-up to have DL attached to the TR. If I can find it and you are interested, let me know and I can get the measurements.
Mike
dyogim.blogspot.com
Old 11-17-2009, 08:02 AM   #53
06silverback
Default
did some more cleaning on the axle last night and "shaved" the bottom of the housing so it wouldnt hang up on anything in reverse...just took cell phone pics.
Sponsored Links
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
High Pinion Dana 44 joel Parts/Electronics/Wheels & Tires For Sale 13 12-23-2008 10:04 PM
Dana 60 front high pinion dstrbd2 Wanted 3 03-06-2008 07:21 PM
tork specs on Dana 44 pinion nut Bear Solid Axle Swap Tech 18 01-08-2008 01:56 PM
Low Pinion Dana 44 chad137 Solid Axle Swap Tech 5 12-07-2005 11:27 PM
Sponsored Ad
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
