Toyota Territory Off-Roaders Association (TTORA)
Toyota Territory Off-Roaders AssociationToyota Territory Off-Roaders AssociationToyota Territory Off-Roaders Association
Sponsored Ad
Go Back   TTORA Forum > General Tech > Fabrication/Tools
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Welcome to the TTORA Forum forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact contact us.
Reply
Thread Tools Display Modes
Old 11-05-2009, 09:37 PM   #1
99BlackTac
99BlackTac's Avatar
Default Rebuilding 8" Toy Housing?
In the not too distant future, i'm planning on a SAS for my 99 Taco. I recently picked-up a front axle from an 85 runner for the build. I know that this axle falls between 5-6" short of what I need, so I had an idea: Is it somewhat possible to cut the knuckles off and cut the housing apart so i'm left with just the 3rd mounting face essentialy, then add tube to my desired length, then add the knuckles?
Before everyone says, "just buy a diamond axle, or Sky, or whatever," I may end up doing that, but i'm just curious if this is do-able or not. I've got nothing but time to work on it, and materials would be rather cheap. Just looking for thoughts/opinions on it, what I may need to consider, what I haven't considered. I know the hardest part would be keeping it straight the whole time with all the welding, but I can work with that/around that. Let me know what you guys think. I might do it anyways just for the sake of doing it, especially since i've already cut the knuckles off!
99BlackTac is online now   Reply With Quote
Old 11-05-2009, 09:40 PM   #2
badmoonrising
badmoonrising's Avatar
Default
its been done but the metal is too thin....i wouldnt want to
Proud member of the
SOUTHERN CALIFORNIA TACOMA CLUB
what the fuck is resale value?
badmoonrising is online now   Reply With Quote
Old 11-05-2009, 09:48 PM   #3
Jomentum
Jomentum's Avatar
Default
get a Fj80 housing ?
Jomentum is offline   Reply With Quote
Old 11-05-2009, 10:33 PM   #4
99BlackTac
99BlackTac's Avatar
Default
I suppose I could use the housing mounting surface and area around/behind it as a template and kinda start from scratch, using 1/2" plate for mounting the 3rd, then build around it with 1/4" plate. Axle tubes would be in the 5/16"-3/8" range i'm thinking.
That would be more $ than i'm looking to spend, plus i'd be flipping it, and i'd feel bad flipping an FJ80 front and risk screwing it up.
Old 11-05-2009, 10:46 PM   #5
88cleve4runner
Senior Member
88cleve4runner's Avatar
Default
could turn into a nice little write up. i say go for it, i've never seen it done. and plus it could give you sometime to brag about when people talk about their bought axle, you can talk about your built axle?
88: Custom sliders and rear bumper and skids
Aussie in the rear, ARB in the front
63 Chevy's, 2 in lift
33x12.50 Maxxis Bighorns
5 spd. 22RE
no gears yet
98: Auto 3.4
DD, stock
88cleve4runner is offline   Reply With Quote
Old 11-05-2009, 10:55 PM   #6
hunter4runner
hunter4runner's Avatar
Default
it's do-able you would have to flip it in the process and you would probably mess something up no offense
The above written is not intended to insult your mechanical ability, it is simply a suggestion or option.
hunter4runner is offline   Reply With Quote
Old 11-05-2009, 11:53 PM   #7
NorcalPR
NorCal Vice Prez
NorcalPR's Avatar
Send a message via AIM to NorcalPR
Default
There's a guy on Pirate IIRC that is a weld on spacer that goes on the short side. You'd need custom made longs for the short side.
Hi, my name is Phill, above are things I say
NorcalPR is online now   Reply With Quote
Old 11-06-2009, 12:55 AM   #8
99BlackTac
99BlackTac's Avatar
Default
Never know till I try, but i'm fairly confident in my fabrication skills if I really take my time on it, set everything up right.
Is this what you're referring too? (Not sure if i'm allowed to site pics right from IH8Mudd, but regardless)
I don't like the idea of adding in spacers like that, i'd rather have one solid piece.
Old 11-06-2009, 01:13 AM   #9
Hoax 56
Senior Member
Hoax 56's Avatar
Default
i say build one from scratch, would be pretty cool to see and wouldnt cost very much. but would be hard to get everything right
'98 ExCab Tacoma 2.7, Few mods..
Hoax 56 is offline   Reply With Quote
Old 11-06-2009, 01:24 AM   #10
hytenor
Bovine Scatologist
hytenor's Avatar
Default
sell it and get a D44.
huge waste of time/$, IMO.
Originally Posted by rojodiablo View Post
But my rear is pretty good, and I have a lot of droop, and a ton of flex.
Originally Posted by =ACID RAIN= View Post
Purrrty, =GAYR= and Cunting-Homo. What's next, Oppositegirl? 5peckers? mypapilloma? Hybendover? Toymasturbator? Mr Baloney?
'00 Excab Tacoma, 2.7, 5sp with a Bunch-o-mods
Inchworm Rock Walkin' Gear
hytenor is offline   Reply With Quote
Old 11-06-2009, 08:37 AM   #11
Backwoodsboy
Backwoodsboy's Avatar
Send a message via AIM to Backwoodsboy
Default
agreed
and uh you need to flip that axle anyways. that mini truck axles are pass side drop. and tacoma is driverside output on the tcase. so yeah you need to flip it.
2001 tacoma trd
92 beater
Backwoodsboy is offline   Reply With Quote
Old 11-06-2009, 03:34 PM   #12
NorcalPR
NorCal Vice Prez
NorcalPR's Avatar
Default
Nothing you can really do since the whole housing is just a top and bottom piece welded together to make the housing.
Best bet is to wait till Dan at Ruffstuff comes out with his housing, or go with a Diamond if you want all Toyota stuff.
Old 11-06-2009, 03:36 PM   #13
NorcalPR
NorCal Vice Prez
NorcalPR's Avatar
Default
x2. I have the flipped housing and I have it because it was cheap and available at the time of getting parts. Worked out in my end. If I were to do it all myself though, I'd just get the right housing and call it a done deal.
Old 11-07-2009, 12:02 AM   #14
99BlackTac
99BlackTac's Avatar
Default
I'll likely end up doing that, but i'm still going to investigate this possibility a bit further.
Old 11-07-2009, 02:22 AM   #15
hytenor
Bovine Scatologist
hytenor's Avatar
Default
it has been done...long thread on Pirate in the Tacoma section.
Old 11-10-2009, 12:26 PM   #16
vegaskurt
Senior Member
vegaskurt's Avatar
Default
There are a few build threads in the hardcore section on ih8mud. I remember seeing one where they extended an fj40 housing. There were pictures taken of the housing as they welded it that showed how easy it is to warp the entire housing.
If it were me, I'd chop the steering balls off and weld them onto a $400 ruffstuff housing. But if your looking for a project, build a jig and go for it.
1997 Limited 4runner | Stubbs Sliders | Budbuilt Skid+belly | Homemade Front / Rear Bumpers
vegaskurt is online now   Reply With Quote
Old 11-10-2009, 09:29 PM   #17
99BlackTac
99BlackTac's Avatar
Default
Yeah i've been looking into those housings, plus i've already got the steering balls off.
Sponsored Links
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
The Ruffstuff 9" Axle Housing! Gravel Maker Sponsors Products 17 09-08-2009 01:05 AM
8.4" diff/housing, 1.5" lift shackles 99' baron Parts/Electronics/Wheels & Tires For Sale 11 07-28-2009 08:00 PM
WTB - 8" V6 rear axle housing RatLabGuy Wanted 1 08-19-2008 09:11 AM
Looking for Tacoma 8.4" diff carrier housing... Landbruiser Classifieds 1 09-27-2007 10:10 PM
stock 8.4" axle housing PappaF2 Wanted 7 01-10-2006 10:55 AM
Sponsored Ad
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
