Welcome to the TTORA Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
I've been using this oil in my truck since I got it 8 years ago. Everyone here in town swears by it. However, it's made just down the road. So I was just curious what everyon elses thoughts were on it. Haven't had any issues, but was just thinking about it. I have heard and experienced nothing but great things, but since it's a local product everone swears by it. Just lookin for an outside opinion.
#2 |
I ran it for a while it's definitely good stuff but not worth the money for my 20+ year old motors.
A cheap sinthetic blend does me just fine. If i had a newish motor i would probably run the Royal Purple though
Doorless Yota Built and Beat
#3 |
you're more than likely going to get blasted for not just searching. most ppl on this board don't like it...claiming they have either had it destroy an engine or know someone that did.
I'm running Mobile 1 in the engine and Redline/Amsoil in the trans/TC/Diffs...but did run the synchromaxx in my old TT Stealth and liked it
BLKTACO 2000 Black 3.4L 5sp 4x4 SR5 Mods: AirRaid M.I.T. with TrueFlow drop in filter/elbow mod, 2 1/2 Daystar full lift kit (M/T Classic II 15x10-BFG A/T 32x11.5), Audio: Pioneer Premier MP3/CD/USB, Infinity Reference component, ED 7kV.2 woofers, ED nine.4, ED eDead ~50sqft Future: TRD SC, FTC, New Tint, Tundra Brake mod, new seats, actual lift kit |
#4 |
Royal Purple is one of the best lubes out there, but there are a few that can hang in there as the best as well. The price is the only thing that gets me. I change oil every 3k so that gets expensive. Regular oil worked just fine for the last 30 years of my life. I would run RP if I was into racing or precision motor rebuilding.
01 SR5 V6, 4.88 Yukon Gears, Lock-Right's Front and Rear. |
#5 | |
#6 |
I LIVE FOR THIS
![]() Join Date: Dec 2004
Never used RP. Any oil pretty much will give you the same results. Ive used Amsoil, Redline, Mobil, Pennzoil Platinum, Syntec...all have givin me pretty good results as far as cleaning. If you want to know what works best get a oil analysis done.
2002 TACOMA 3.4L 102K AND COUNTING |
#7 |
Just don't use the gear oil in your trans.(if it's a manual) because it sucks ass! It also eats at the brass syncro's.The Toyota trans. don't like gear oil.You must use a manual trans oil.Maybe RP makes one now,i don't know.But the motor oil is good,just remember it is NOT full synthetic,so to me it's over-priced.
#8 |
Fawking Fly's
![]() Join Date: May 2005
just replaced all the lubricants today...
axle's = Mobile 1 Trans = Amsoil -------------- } best choice for these. IMO TCase = Amsoil Engine = Mobile 1 I've also read several complaints about RP used in the trans... But never cared to find out fer myself. |
#9 |
I've run RP and I'm running Mobil 1 all the way around now. And the RP is not worth the extra money IMO. I like the Mobil 1 the best in my motor, axles, and T-Case. Its ok in the trans.
2001 Tacoma Reg. Cab. 2.7L 4wd 5 Speed. OME 881 up front and Dakars in the rear Pro Comp 7089, 265/75R 16 Cooper STT Defiant LB with some PIAA's and Hellas CBI rear bumper www.treadlightly.org |
#10 |
Elder Member
![]() Join Date: Mar 2007
#11 | |
Fawking Fly's
good to see that old shit get retired... or maybe it's just wishful thinking when it comes to choice snacking. thanks fer helping me change out the lubricants on my junk sunday.
#12 |
amsoil, go with amsoil. Iv heard good and bad about RP, i ran it in my jeep which did well.
but it doesnt compare to amsoil. a little cheaper too.
"Meg!! Meg!! look Meg look I am so freakin good at colorin, I know I not suposted to go outsid da lines, but I do anyway cuz I like bein mysellf!"
#13 |
unless you're having it analyzed, there's no way to tell if one oil is better than another.
post up if you have some data backing your claim.
04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's |
#14 | |
http://www.amsoil.com/lit/g2457.pdf Yes this is an amsoil study - though as legit as any outside source from the looks of it. Have a look and see. I have personally never heard any good things about Royal Purple from any "backed" perspective. |
#15 |
i would only use RP for high performance applications. trucks dont need RP. stick with good ol cheap dino oil or mobil 1 every 3k-5k/7.5k and you will be fine.
99 4 banging taco |
| Sponsored Links |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Royal Purple 75W-90 | ThunderOne | Early Tacoma Tech | 30 | 06-15-2009 11:48 AM |
| royal purple synthetic oil | ocreptileguy | Performance/Engine/Exhaust | 16 | 03-31-2009 06:03 PM |
| Royal Purple... | ben90 | Newbie Tech | 19 | 03-31-2009 05:20 PM |
| Royal Purple vs AMSoil | 04RedLobster | Performance/Engine/Exhaust | 5 | 06-02-2005 01:01 PM |
| Royal Purple Kicks Arse | CMB1998 | Early Tacoma Tech | 7 | 03-05-2005 02:48 AM |
