Go Back   TTORA Forum > Rock Crawling Tech > Solid Axle Swap Tech
Old 11-06-2009, 12:15 PM   #1
Jeffsgotayota89
Default Wagoneer Axles
Quick question guys. I am looking to start a solid axle swap on my 88 yota. My question is, should I pick up an available 1990 wagoneer for 300 bucks for that axle? Its even running, but doesnt have rims or tires. I tried searching and found that an axle from 86-91 wagoneer would work, but that 89 is the best year. Any help or suggestions?
Thanks,
Jeff
Jeffsgotayota89 is offline   Reply With Quote
Old 11-06-2009, 12:22 PM   #2
Jeffsgotayota89
Actually, might not work now. Since the Wagoneer is an auto that probably means it has the vacuum disconnect, correct?
"A dash-mounted control allowed the driver to change between two or four wheel drive. The switch activated a vacuum-activated spline clutch that was built into the front axle assembly."
Old 11-06-2009, 08:06 PM   #3
deange
deange's Avatar
Why not just use a yota axle? Everything is very well mapped out and pretty simple. If you just want a Dana axle why not source a Chevy D44?
It isn't that we are all that good, It's just that everyone else sucks so very badly.
deange is offline   Reply With Quote
Old 11-06-2009, 09:10 PM   #4
C4 Cory
is it 5 or 6 lug cause I think if it is the 5 on 4.5" lug pattern is a dana 30
04 Tacoma D-Cab TRD 4wd
85 4wd pickup (or, whats left it)
C4 Cory is offline   Reply With Quote
Old 11-08-2009, 10:09 PM   #5
mrkarl00
mrkarl00's Avatar
IIRC, the waggy i pulled my 44 out of was an auto, and it doesnt have the vacuum crap, but it was an 87.
'98 tacoma extended cab
SAS Dana 44 with the works
mrkarl00 is offline   Reply With Quote
Old 11-09-2009, 12:45 PM   #6
Jeffsgotayota89
I would love to use a toyota axle. Have been looking for one in my area for a while now. Someone is selling one right now on Craiglist for 625. Which seemed pretty steep. But I have ran info a few wagoneer axles and I know some people put them under their yotas. I figured I would go that route since I am having a hard time tracking down a toyota axle.
Old 11-17-2009, 11:12 PM   #7
Slayer
Stay away from the 82-83 wagoneers with the vacuum disconnect. The 1990 axle should work great and has 30 splines i believe.
Slayer is offline   Reply With Quote
Wagoneer axles yotabooga Newbie Tech 1 04-03-2009 09:46 AM
wagoneer axles ? tacoma.22 Solid Axle Swap Tech 17 03-14-2009 11:51 AM
f-150 or wagoneer axle yota steez Early Tacoma Tech 9 11-12-2007 09:57 PM
Wagoneer axles Scretagent Wanted 0 11-01-2006 07:46 PM
77-78 wagoneer 99FlowedTaco Classifieds 3 09-07-2006 11:53 PM
