Toyota Territory Off-Roaders Association (TTORA)
Toyota Territory Off-Roaders AssociationToyota Territory Off-Roaders AssociationToyota Territory Off-Roaders Association
Go Back   TTORA Forum > General Tech > Suspension
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Welcome to the TTORA Forum forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact contact us.
Reply
Thread Tools Display Modes
Old 11-06-2009, 08:20 PM   #31
rosscopeeko
Senior Member
Default
goliath, are you still running your 5100 rear shocks with the 3" lift? Any problems there? I'm going to run the exact setup as you.
97 s/b 2.7, trueflow filter, jardine catback, lce header, bilstein 5100's. otherwise stock with 265/75/16's and matching cap.
rosscopeeko is offline   Reply With Quote
Old 11-06-2009, 08:34 PM   #32
goliath_2
goliath_2's Avatar
Default
Yup, still have the 5100s. They seem to be working fine so far. I definitely think they're at their limit and the leafs easily gave me 3" of lift (maybe a tad more). What would I notice if they were too short? hahaha...
goliath_2 is offline   Reply With Quote
Old 11-06-2009, 08:56 PM   #33
goliath_2
goliath_2's Avatar
Default
Shoot - now you've got me thinking they may be too short... I mean, the seemed to fit when I was installing everything... Maybe I should get longer ones? I wouldn't mind trying out the softer valved OMEs... SHOWSTOP, do you have any input here? Thanks...
Old 11-08-2009, 02:49 PM   #34
kigmob
Senior Member
kigmob's Avatar
Default
Hey goliath 2 how bout some measurements from the ground to your fenders? I am thinking about going with the same setup you got in the rear but would like to see exactly how high the truck is from the ground. Front measurements would be nice too as I may consider putting some eibachs on my billies up front, my front coils seem pretty tired...Thanks!
1997 Taco 4x4 V6 5spd
5100's At 2.5"
Block In The Rear
32x11.50 BFG All-Terrain T/A KO's
Flowmaster 40 Series
Custom Spectre Intake
ScanGauge II
PIAA Intense White Bulbs
Roundeyes Dome Light
kigmob is offline   Reply With Quote
Old 11-08-2009, 05:50 PM   #35
goliath_2
goliath_2's Avatar
Default
With the bed empty and a full tank of gas I have 40" from the ground to the fender flare in the rear and 38.5" in the front. I have 31" tires right now. Hope that helps.
Old 11-08-2009, 07:25 PM   #36
wisehybred
Default
Im about to order the Eibach springs and bilstein adj. for the front. Calling Alcan in the morning to get a custom pack going.....dakars were my first option, but Im going to relocate the spring hangers so Im going the custom route not that much more expensive.
2000 Taco 3.4L Ext cab
2.5 SAWs, 1.5 AAL rear 5100's and new Aux lighting BFG 32x11.50x15
97' Taco 3.4L Ext cab
Bone stock as of now
wisehybred is offline   Reply With Quote
Old 11-08-2009, 09:27 PM   #37
kigmob
Senior Member
kigmob's Avatar
Default
Thanks man!
5100's At 2.5"
Block In The Rear
ScanGauge II
Old 11-09-2009, 10:32 PM   #38
wisehybred
Default Just an update
I was back and forth between the Dakars and Alcan but have decided in the end that a custom pack will be the best option for my truck. Dakars are not meant for the 97 yotos. They will not warranty them if damaged....yes they are very inexpensive at 299 but for what it’s worth im going custom, I need the versatility of load capacity, highway use and Texas off roads. Besides with the Alcans you can have them make whatever size lift you need, in my case I’m going to run 33x10.50's so a 2.5" lift will net about 2" in the end after initial sag, also going to add 1inch body lift to help with tire clearance. In the bed I will have about 200lbs of tools/recovery gear loaded at all times, as well as weekly weekend trips with kayak, fishing/camping gear and 100+ miles of highway driving. Comfort is important as well on long road trip of Texas terrain.
Old 11-17-2009, 07:42 PM   #39
rosscopeeko
Senior Member
Default
Guys i need your opinion on the bushing for the 92 springs. I found the springs and have them sitting, just need to pick them up. I ordered rear leaf bushings for a 92 truck, energy suspension, and now i'm worried they won't fit my 97 truck? Are they the same bushings, or do i need to order 97 specific bushings?
Old 11-17-2009, 08:51 PM   #40
goliath_2
goliath_2's Avatar
Default
They'll work - that's what I got. Read earlier in the thread: "BOOM: http://www.toyteclifts.com/index.php...mart&Itemid=72
Daystar website:
Part# KT02008BK
Spring & Shackle bushings
96-04 Tacoma 89-95 Pickup Spring Bushings Rear "
Old 11-18-2009, 12:05 AM   #41
rosscopeeko
Senior Member
Default
Thanks again Goliath.
Sponsored Links
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Leaf spring size "OME question" duc Newbie Tech 0 02-17-2007 08:24 AM
Need Sway-A-Way 2.0" Coilover 675Lb x 15" Spring(s) crawler#976 Wanted 3 12-20-2006 03:01 PM
Picking up workers.... Reebles Off Topic 15 07-04-2005 12:04 PM
Help on picking an AAL (who has this one) renzo626 Suspension 3 01-17-2005 03:14 PM
Yeehaw! Picking up 2" PA Body Lift this weekend... 4x4Dragon Early Tacoma Tech 32 12-25-2004 01:44 PM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
