Welcome to the TTORA Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
Newbie
05+ TACO Prerunner
Wanted to share my installation of a DieHard Platinum Group 65 AGM battery. Which many claim to be a private label Odyssey PC1750 made by EnerSys. This is the largest AGM battery Sears sells with 48 month free replacement, then 52 month prorated warranty. 930 CCA / OEM Toyota 710 CCA 135 min reserve / OEM Toyota 165min reserve claimed(more like 70 minutes) claimed weight 60lbs. / ACTUAL weight 53.5lbs / OEM Toyota Group 27F 49lbs. At first, it appeared the positive battery cable to the fuse box & ground cable would need to be lengthened. Load and behold, such measures were not necessary. There are 2 ground locations on the right side of the battery. Just swap locations. Now, the ground for the fuse box (two white wires w/black stripe) will need more slack. Open the wire loom by removing the electrical tape. Pull until desired length is reached. Then using new electrical tape, re-seal wire loom. I also used 3/8" heat shrink tube on the newly exposed two white wires w/black stripe. Install battery. The ground cable fits because a Group 65 battery is 1 3/8" shorter than a Group 27. I used an aluminum battery tie down & fabricated a rear hook(Home Depot). The front hook is OEM Toyota. battery weight<p> <br>ground location swapped<p>
#3 |
Dun DUn DUN!
![]() Join Date: Dec 2004
its still a wet battery right??? or does it have some sort of mat or other....?
99 Taco with 5 inches of lift and some toys... |
#5 |
Any threads or pics of how to hold a battery down in a wheeled rig? I've got the same tension plate hold down and my battery moves around quite a bit.
#6 | |
![]() Second...Yes, something like this is a good start! ![]() ![]() http://www.ballisticfabrication.com/...x-_p_1673.html
'98 SAS on 37's |
| Sponsored Links |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| DieHard Platinum mounting bracket | D DUBersons | Interior/Electrical/Electronics | 1 | 10-26-2008 10:19 PM |
| Group 27F battery | Switch | Classifieds | 3 | 04-30-2008 10:28 PM |
| skyjacker Platinum Series | 04RedLobster | Suspension | 4 | 04-21-2006 08:05 PM |
| No Platinum Plugs?? Why Not? | Beave | Early Tacoma Tech | 12 | 01-28-2005 09:35 AM |
