Welcome to the TTORA Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#121 |
Senior Member
Hi. I see that the adapter plates are still not available from ruffstuff and the ones listed on Sky are for chevy calipers. Would those brakets from Sky work for the front Tacoma calipers? Mine are from a 2002, so it came with 16" wheels. Or does anyone know who else would make a bracket for Tacoma calipers? Thanks
http://www.ruffstuffspecialties.com/...per-p-111.html http://www.sky-manufacturing.com/new...uct.php?id=128
'02 Double cab, 5 speed swap, dual T-cases, FJ80 SAS, dual E-lockers, 37" MTR's '80 Pick-up, '80 cab with '02 double cab chassis, 3.4L V6, 5 speed swap, IFS, airbag, air, power doorlocks, etc. |
#122 | |||
Bovine Scatologist
![]() Join Date: Dec 2004
...never seen any other brackets for disc calipers other than FROR's Supra rear discs that are no longer available.
Inchworm Rock Walkin' Gear |
#123 |
Senior Member
OK thanks. So, would they require a bit of grinding, or is it a complete fit?
#124 | |
sky's brackets fit tacoma axle 'ends' and CHEVY calipers... NO, Chevy calipers and Tacoma calipers are not in the least bit interchangeable.
+( )X( )=
#125 |
Senior Member
Oh OK, I get it now. Thanks. Does anyone perhaps know what the exact offset of the brackets is? I see that they are bent to the outside, and I'm thinking I'd be better off if I make my own brackets that will fit the Taco calipers I already have.
#126 | |||
Bovine Scatologist
do you have a plate bender that can handle 5/16" plate? that's what you'll need.I do have the Sky kit including the Chevy brake parts fs ...got them on a Diamond axle that I just bought and don't need them. Rotors, calipers, pads, brackets. They are front calipers so no ebrake.
#127 |
Senior Member
No, but I actually had no intention to bend the plate. Instead I can cut the plate out of 1/2" steel and then weld the appropriate size spacer to the outside of the plate to give me the correct offset for attaching the Taco caliper. Would still be a lot of work, though, but so far my truck is 100% Toyota, and I plan on keeping it that way. No chevy calipers, please.
#128 | ||
Bovine Scatologist
take pics and do a writeup if you're able to make the Taco calipers work
#129 |
Senior Member
I think I'll try the SKY brackets with the Chevy calipers.
Deacon 03 DC Warn winch, AllPro rear bumper DeMello sliders, front bumper, 1 in BL Donahoe's front & Deavers rear, 33's dual battery, Bushwacker flares Tundra front brakes |
#130 | ||
Bovine Scatologist
I have a brand new set, brackets, rotors, calipers and pads...will sell for a lot cheaper than off their site. they came on a Diamond axle I just bought...have no use for the brake parts.
![]() Sky brackets Monte Carlo rotors, calipers, pads
#131 |
Can anyone please put all this info together in a step by step process with parts and tools and how to/pictures and hook a guy up. I feel like I'm piecing 10 different web sites together trying to get the same thing, I'm confused as hell now. I did a rear brake swap on my 87 4Runner(some problems) and now I want to do it to my daily driver 2000 Taco.
And another question, does anyone make a transfer case disc brake dealywhoo for Tacoma's? Thanks, Chris
Yotastalker is mah name, cuttin, weldin, is mah game. ![]() http://www.myspace.com/chrisandstuff 2000 Taco w/ ICON 2.5in lift, yokohama's, rocksliders. 87 4Runner SAC'd w/ lots of stuff 2003 Tundra junker in storage
#132 | |||
Bovine Scatologist
#133 |
The Un-people person
I talked to PartsMike at the easter jeep safari in Moab about using his caliper for the atlas and modding it onto a mount for the tacos. I still have all the trial stuff from the Ballistic one so I planned on just modding the old mount to hold the better caliper from Mike and using one of the rotors I already had. Just haven't had the money or time to pick up the caliper lately.
1998 SR5 TeRD 4x4, Front Pro Rock D60 w/ Dedenbear kingpin and ARB locker, Rear 35 spline D60, locked, rear disks, 4.7 crawlbox, 40" Swamper LTB's, 17" Stazworks double beadlocks, 9000# T-Max comp winch etc... My other SAC My out of date Website under construction For those of you interested in Throttle body spacers: Click here |
#134 |
Senior Member
is there a reason why no one has made a t-case e brake for the taco yet??? cause i need to figure out an e brake setup..
'98 ExCab Tacoma 2.7, Few mods..
#135 |
I haven't had an e-brake for years now. Some people really like the line locks. If you go that route I recommend a manual one that doesn't require electrical power to keep it engaged.
#136 | ||
Bovine Scatologist
something to do with clearance issues. Balistic tried but it didn't work so he discontinued it.
#137 |
Senior Member
well if i was to install a line lock, since that is about my only option, where do most people put it? inside the cab or what? cause that would seem like a pain to run lines into the cab...
#138 |
Senior Member
Others may have different opinions/ suggestions, but first thing to remember is that they are illegal on the road. The electrical ones can be mounted on the firewall by the brake booster, but you cannot leave them on and as far as I know, the best place to mount the manual ones is by running lines into the cab. You may be able to use an actuator, like a power antenna or cruise control actuator to actuate the manual linelock remotely with a switch, though.
#139 | ||
Senior Member
I lived in a trailer while I was putting myself through college. Joke if you want but I am not ashamed of it, this way I still had some funds for wheeling. Quote:
![]() It now has my own custom leaf pack back there without the block. Oh and the spacers are to make the rear match the full width d44 front. Its amazing how you leave a thread for a little while and people start talking smack ![]() BTW This setup is still working great on my rig. Any more questions let me know.
WWW.BUSTEDKNUCKLEFILMS.COM *GET YOUR COPY OF THE DVD starting Nov. 1st 2009* SAS'd on EB coils and 3 link hp ford dana 44 36 iroks http://www.tacomaterritory.com/forum...2&page=3&pp=30 |
| Sponsored Links |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rear Disc Conversion using stock rotor/caliper? | Valkyrie | Early Tacoma Tech | 32 | 11-05-2009 01:37 PM |
| rear disc brakes | faithoffroad | Fabrication/Tools | 19 | 10-11-2006 01:29 PM |
| 06' Tacoma rear disc conversion | travis9 | Late Tacoma Tech | 20 | 05-30-2006 01:16 PM |
| Rear end clunk (not axle wrap?) | BajaTaco | Early Tacoma Tech | 28 | 04-07-2005 06:30 PM |
