Welcome to the TTORA Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
Senior Member
I have a 03 Dcab with a fiberglass camper top. I'm looking for ideas on a "clean" mount. A magnetic mount would just get knocked off on my car port. i'm leaning toward the Firestik MKM2 side body mount, but the question there would be where to mount it? Or, the Firestik DS14-FG(cell look-a-like)...it would mount to the top of the camper shell towards the cab. Has anyone used either of these applications and could post pics?
I've also condidered a hood mount(left side)as well.
2003 Tacoma PreRunner V6 SR5 Double Cab There are many choices in life, Eternity only has two. http://www.myspace/tacoma03 bigbadjohn007@hotmail.com John Seltzer
#2 |
check this post. CB antennae w/ FG camper..
found in this thread.. http://ttora.com/forum/showthread.php?t=143519 |
#3 |
Senior Member
I like how that looks. I wonder about the grounding issue though.
#4 |
hell is other people
roof mount wilson whip.
FUCK SURFINGDRUNK "There is nothing good or bad but thinking makes it so". Bill Shakes I love to buy my parts from trdparts4u.com!
#5 |
I took a second look at the ground too.
My antenae while mounted to a mount connected to my bed toolbox, Is grounded to the bed. ![]() Seem's to perform okay for not being tuned ![]() Good luck |
#6 | ||
Bovine Scatologist
![]() Join Date: Dec 2004
yup, drill the hole. on the Dcabs that really seems to make a huge difference in ground plane...send/receive is way better than any other mounting...ask Mark
Inchworm Rock Walkin' Gear |
#7 |
Senior Member
#8 |
Newbie
i'm getting ready to install a cb and antenna as well. contemplating hood/fender, tailgate jamb, or center of the bed for the antenna. Will someone:
1. someone explain grounding plane a little more to me? i have read other posts on this but I am still confused. 2.does the antenna always need to be grounded or is that just dependent on location? also i guess the longer the antenna the stronger the signal? |
#9 |
I was reading this the other day
http://www.firestik.com/Tech_Docs.htm Pretty good read.. From what I understand, Ground plane is just the fact that you have metalic surface on your truck. Non ground plane would be a whole fiberglass RV or the like.. If your antennae has a ground wire on it, Yes it needs to be grounded. |
#10 | |||
Bovine Scatologist
Some antennas are self-grounded so check the specs of whatever you are looking to buy. No, antenna length doesn't make it any better. Even a cheap antenna positioned correctly and tuned via an SWR meter will out perform a top quality antenna that is just stuck on the truck any ole way and not tuned ![]() Time for Showstop's input
| Sponsored Links |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| FOR SALE - Cobra 75WXST, S/S Antenna Mount, Antenna and Wire | mdbmxdad | Parts/Electronics/Wheels & Tires For Sale | 7 | 08-22-2009 05:35 AM |
| antenna mount | 1bdtaco | Interior/Electrical/Electronics | 4 | 01-31-2009 02:41 PM |
| CB Antenna Mount | ah64id | Late Tacoma Tech | 48 | 08-17-2007 10:29 AM |
| cb antenna mount | blackbear | Interior/Electrical/Electronics | 9 | 10-02-2006 05:37 PM |
| CB Antenna mount | ripkinC | Interior/Electrical/Electronics | 36 | 03-26-2006 10:13 PM |
